lt1 knock sensor?
If a Pipe wrench isnt working you may have to drill it out. I wouldnt recommend that unless as a last resort. FYI Coolant is gonna come outa that hole and splash you in the eye.
Also you may want to get the LT4 knock Modual as stated above.
I used a strap wrench, which wasn't working well, then I screwed it up some more with a set of vice grips. At the end of the day I stabbed it with a large screwdriver til I punctured it and twisted it off that way.
Its bitch and won't come out easy.
If you are replacing it, get the new sensor from GM. It needs to be torqued properly also, get the torque number from the dealership.
I got a new sensor from NAPA and it was no good, it dosen't cost hardly anything more at a dealership, so get it from the dealership.
http://shbox.com/1/ks_2.jpg
if you look at this picture, you see that outside looking shell that crimps over onto the inside area where the socket would go, well that inside area kinda just spins inside that shell.
What do you have on your car? Anything that could cause the 3 degrees of knock in the first place?
Ask at the dealership what the torque spec. is, unless its listed on shoebox's site or someone on here knows. I know I couldn't find the number in the Haynes or Chiltons.
Here is my horror story with my knock sensor.
I was replacing my head gaskets, timing chain, springs, rockers, etc. Basically rebuilding everything but the shortblock.
So I also wanted a new knock sensor.
No torque specs listed in either book, got the part from NAPA. Took me hours to get the old sensor out. When the car was all put back together I had a code 41 or 43 or something, the code for ESC control. Yeah the knock sensor from NAPA was bad, which I couldn't think possible. Finally I took it to the dealership, resistance number was way off on the NAPA sensor, I just gave up and paid the dealership to fix the issue, no more check engine light.
I take it your just seeing the knock on a scanner, and not throwing a code for the KS??
I got mine tuned for my setup, didn't really need the LT4 Knock Module.
Well you have to be careful now though, ask at the dealership what it should read resistance wise, also to read out the voltage going to it.
A few things could go wrong with ESC, the knock sensor, the knock module, and also the PCM can be at fault.
