k member removal questions
Old Jan 8, 2007 | 03:38 PM
jester1614's Avatar
Default k member removal questions
lots of questions for you guys
anyone have a write up?
I am going to use a chain around a 4x4 to keep the engine up while i remove it. any one have a better idea I cant afford to buy a tool to use it just this once.
where do i attach the chain to the engine?
any hints
Old Jan 8, 2007 | 04:46 PM
jester1614's Avatar
sorry about that i would be putting the wood on the strut towers
Old Jan 8, 2007 | 04:50 PM
the_merv's Avatar
Veteran: Air Force
Why are you droppong the K-member, getting a Tubular one?
Old Jan 8, 2007 | 05:10 PM
95FbFormula's Avatar
?? you are using a cherry picker right.
Old Jan 8, 2007 | 09:26 PM
hyperzone's Avatar
he said he doesn't have the $$$ to buy one for just this one time thing...
I would recommend asking for some local help and maybe borrowing or renting a picker. The 4x4 thing sounds F***ed-up. TPIS sells a thing called the "happy hooker" which is for picking an LT1 up from the top. Or, you can just bolt a chain to whereever you can on the heads or block.
As for pulling the K-member, why?... You will need to undo your brake lines, ABS sensors, calipers, power steering rack, struts, and swaybar before you can drop it out.
Hope you have a compressor and a air wrench....
Old Jan 9, 2007 | 01:06 AM
Hmm well I wouldn't trust the 2X4 If you have a garage use 1 of the cross beams to hook a chain to or some type of hoist then bolt it to the motor.
Old Jan 9, 2007 | 04:45 AM
jester1614's Avatar
i have figured that i will use something bigger than a 4x4 probably a 6x6 and the reason i am doing it is that my cross member is bent and needs to be replaced. i will be renting a air compressor and some tools
Old Jan 9, 2007 | 04:51 AM
jester1614's Avatar
and i will probably end up renting a cherry picker and using that just throwing ideas around in my head
Old Jan 9, 2007 | 05:35 AM
hyperzone's Avatar
bent? how bad? you doing this all by yourself?
Old Jan 9, 2007 | 05:39 AM
jester1614's Avatar
i am unsure of how bad
i bought the car after a wreck and the body shop told me it needs to be replaced
just so happens i have a spare one
a friend will be helping
Old Jan 9, 2007 | 06:48 AM
the_merv's Avatar
Veteran: Air Force
That's a good little hit to get bent..
