founf this chart, are these good guid lines????
Im new to using a wideband lm-1 meter and i found this chart online. Im trying to figure if the reading im getting from my car are correct. Are the reading in the chart below good to use as guide lines????
Cold Start (first 30 sec)
11.5-12.5 AFR
Idle
12.8-13.5 AFR
Part Throttle Cruise
13.0-14.0 AFR
Wide Open Throttle
12.5-12.8 (values down to 11.5 may be used to reduce detonation) AFR
11.5-12.5 AFR
Idle
12.8-13.5 AFR
13.0-14.0 AFR
Wide Open Throttle
11.5-12.5 AFR
Idle
12.8-13.5 AFR
13.0-14.0 AFR
Wide Open Throttle
11.5-12.5 AFR
Idle
12.8-13.5 AFR
13.0-14.0 AFR
Wide Open Throttle
Good luck, Ed
