megasquirt in a 95 z28
Old 04-11-2008, 03:12 AM
SCTA's Avatar
What type of injection are you planning on going with? Bank to bank or SEFI? Without a cam sensor you can't run SEFI. I don't know if this has any relavance to your question, just something I noticed was not mentioned. I use a IPU trigger on both the crank and cam for mine. Although its not a MS, they all operate on the same principles.
Old 04-11-2008, 06:01 AM
engineermike's Avatar
I think MS will only do bank-to-bank.
Old 04-11-2008, 07:25 AM
wannabess's Avatar
Originally Posted by seank
I'm not a fan of doing that because you're creating delays, plus the uneven pulse widths might cause it to fall out of sync(they will be uneven because the tach pulse will depend on timing advance calculated by the stock PCM). The PNP setup uses the OPTI signal.
Which tach output are you talking about, this one supplies "The Tach Output Terminal produces a 12 volt square wave signal with a 30° duty cycle."
Originally Posted by will62085
I know the output from one of the MSD boxes drives my stock tach wild at high rpms/high rate of change of RPM.
Did you take the bypass filter out of your tach wire, it says you have to on GM tachs, or it wont work properly.
Old 04-11-2008, 08:12 AM
will62085's Avatar
yeah I've run a new wire directly from the MSD box straight to the back of the tach. That helped, but its still off
Old 04-11-2008, 10:50 AM
seank's Avatar
The tach signal is the most important signal with MS or any other ECU. You want to directly piggy back off of a crank or cam sensor. The more hardware you add in the mix the less true the signal becomes. Maybe I miss understood what you were saying. I did a simple sketch below. Which one were you talking about doing.
Best
OPTI-<<<<<-Megasquirt
Best
Crank Trigger-<<<<-Megasquirt(OBD2 LT1 Only)
Have never tested this, but it might be acceptable
OPTI-<<<<<-Stock ECU-<<<<Megasquirt
OPTI-<<<<<-Stock ECU-<<<<-MSD-<<<<-Megaquirt
-sean
Quick Reply: megasquirt in a 95 z28
