hooker or pacesetters long tubes?
Old Feb 11, 2007 | 06:35 PM
FIREHAWKONNOS's Avatar
Default hooker or pacesetters long tubes?
which header makes more power cause i see the hookers are quite a bit more$$
Old Feb 11, 2007 | 06:57 PM
the_merv's Avatar
Veteran: Air Force
Pacedsetters are going to be the best bang for the buck..
Old Feb 11, 2007 | 07:05 PM
Ralls's Avatar
Yet another one of these...
Same power, different prices. Get pacesetters
will they be better then eldebrock mid lenghts?
Old Feb 11, 2007 | 07:07 PM
also which header fits better and is easier to change plugs with cause these eldebrocks suck when working on the car
Old Feb 11, 2007 | 07:08 PM
eLTwerker's Avatar
Most LT headers will flow better than mids, or shorties for that matter.
I had a good experience w/ Pacesetters, but I only had em in for about 6 months. No rusting or torquing issues, though.
Old Feb 11, 2007 | 07:10 PM
Feenix's Avatar
Yes, if you've not got a set of headers yet, LT's will be best bet.
Get pacesetter.
Old Feb 11, 2007 | 07:11 PM
donkey mule's Avatar
I've got pacesetter LT's and like them. The Pacesetters get The same hp and are cheaper.
Old Feb 11, 2007 | 07:14 PM
the car has the mid lenght eldebrocks on it but i'm pulling my engine for a rebuild and am thinking of changing the headers
Old Feb 11, 2007 | 07:16 PM
Ralls's Avatar
Yes, LTs are easier to install and change plugs. Ditch the edlebrocks
Old Feb 11, 2007 | 07:32 PM
the_merv's Avatar
Veteran: Air Force
30 min changeout on all 8 Plugs in my LT1, no bullshit..
Old Feb 11, 2007 | 07:40 PM
crb806's Avatar
from what i have heard hooker headers are a higher quality header and have thicker flanges, both of the shops around here that i have been to dont recommend pacesetters, they work on mostly fbody cars...
but then again pacesetter is probably the best bang for your buck
but get LTs for sure no matter what you get
Old Feb 11, 2007 | 07:46 PM
Feenix's Avatar
I was actually shocked at how nice the welds were on my pacesetters and the flange was just fine. If I'd had it to do over again, i'd have still got the same coated pacesetters on the car now.
Old Feb 11, 2007 | 07:53 PM
the_merv's Avatar
Veteran: Air Force
Yea, mine were great. I had an old set of Pacesetter Shorties on it once upon a time, and they were crap. The LT's are nice.
Old Feb 12, 2007 | 12:00 AM
Mighty Whitey's Avatar
if I were to buy another set, I would go with the pacesetters over the hookers I have now... simply because of price... I got a really good deal on my hookers, and that's the only reason I've got them instead...
I've seena couple pacesetter's break the welds where the tube meets the flange.
on top of that, it seems like my hookers still LOOK better than pacesetters under the hood... they both will rust under the car, but my hookers still look black for all you can see from under the hood, whereas all my friends with pacesetters (5 of 'em) their headers are rusted under the hood... they just don't look as good over time.
surprisingly, my hookers have ZERO leak problems on the driver's front primary where they slip-fit together, guess I lucked in to a good set..
personally, I prefer tube routing of the pacestter on the pass. side, over that of the hooker's... you have more room to get your hands down in there to change all the plugs. but I prefer the hooker design on the driver's side, for the fact that putting the bolts in is MUCH easier, w/o the #1 tube running over top of all the rest.
hookers all around, pacesetter if you've gotta pay for 'em!
Old Feb 12, 2007 | 12:04 AM
Speed Density's Avatar
hashtagBMW
Just installed some pacesetters on a buddys car. Did the plugs AND new wires in about 45minutes. Its all routed OEM.
Tony.
Old Feb 12, 2007 | 12:04 PM
azvforce's Avatar
My pacesetters have the thickest flange I have ever seen on a header. Keep in mind that Pacesetter has made design changes/improvements since they started selling these.
Old Feb 12, 2007 | 12:17 PM
ws6chicken's Avatar
I went with pacesetters due to the price and also the fact that each bank is one piece where as with the hooker LT's you have a pipe that you have to install on drivers side that goes around the steering knuckle; my decision was completly a personal prefrence thing i dont know which pipe routing way is better.
And also took me about 30 min to install plugs and wires without the alternator
Old Feb 12, 2007 | 04:09 PM
Lethal Z's Avatar
+1 for Pacesetter mids ceramic coated. Love them, great low end and great flow up top.
Old Feb 12, 2007 | 04:21 PM
97ssmokem's Avatar
-1 for pacesetters I had nothing but problems with mine. I through them in the trash and got a set of jet hot long tubes. +1 for jet hots.
