what is this cam x97c
Old Feb 15, 2007 | 03:37 AM
thedreamer's Avatar
Default what is this cam x97c
hi
i bought lt1 motor and when i opened it i found camshaft x97c rr 257.265 hydr 112 but i can't read the name on it so can u help me find more info about it
thanks a lot
Old Feb 15, 2007 | 04:33 AM
Speed Density's Avatar
hashtagBMW
RaceCar!!!
Sounds like it might be a custom grind from the previous owner.
Tony.
Old Feb 15, 2007 | 04:36 AM
thedreamer's Avatar
Originally Posted by Speed Density
RaceCar!!!
Tony.
do u know which brand
Old Feb 15, 2007 | 04:40 AM
hashtagBMW
Could be anybodys camshaft.
I want to say Comp, just because thats run of the mill. But i would think it would be 'cc' rather then just 'c'.
Were did you get the motor?
Tony.
Old Feb 15, 2007 | 05:29 AM
thedreamer's Avatar
i get it from junkyard but its for camaro 1995 and the engine is stock but with cam
Old Feb 15, 2007 | 08:58 AM
the_merv's Avatar
Good find.
Old Feb 15, 2007 | 02:59 PM
1997bird's Avatar
Can you show us a picture of the camshaft were it is ingraved?
Old Feb 15, 2007 | 05:23 PM
seawolf06's Avatar
Take or send it to someone that has a cam doctor or degree it in. Then you'll know for sure.
Old Feb 16, 2007 | 05:08 PM
thedreamer's Avatar
its not clear if i picture it
Old Mar 1, 2007 | 08:47 PM
thedreamer's Avatar
see pictures
Attached Thumbnails what is this cam x97c-02032007117.jpg   what is this cam x97c-02032007118.jpg   what is this cam x97c-02032007119.jpg
Old Mar 1, 2007 | 09:17 PM
the_merv's Avatar
What is on the top part of it..
Old Mar 1, 2007 | 11:04 PM
mikes98z's Avatar
If I am not mistaken that is an Isky cam.....looks like XYK on top....call them and find out.
Old Mar 2, 2007 | 04:36 PM
thedreamer's Avatar
hi
as i told u befor from up to down
x97c
(name ican't read it)
101 112
rr 257.265 hyd
211
any idea
Old Mar 5, 2007 | 02:35 AM
thedreamer's Avatar
up up
Old Mar 5, 2007 | 09:26 AM
camzaro28's Avatar
HAHA, I have that same cam I believe. Sitting right in front of me. But your numbers are a lil different. But the 257/265 is the part number, which is the one I have.
Iskandarian
Old Mar 5, 2007 | 09:36 AM
camzaro28's Avatar
Old Mar 13, 2007 | 05:02 AM
thedreamer's Avatar
Iskandarian
Thanks a lot
i found it and its part No. 201257/265
Grind No./Type
RR-257/265 HYDRAULIC ROLLER Excellent performance cam with good vacuum good idle. 3.08-3.73 axle ratio. 9.5
1 compr. Up to 650 CFM Carb. Computer compatible. Stock converter. RPM-Range
1400-5600 Valve Lift - INT
.465
but is it good for LT1
Old Mar 13, 2007 | 05:17 AM
thedreamer's Avatar
i found other number i don't know which one is mine
grind no. /type rr-257/265 hydraulic roller application excellent performance cam with good vacuum good idle. 3.08-3.73 axle ratio. 9.5:1 comr. up to 650 cfm carb. computer compatible. stock converter rpm range 1400-5600. valve lift .465 .485 valve lash h
Mfr Part #: 261257/265
