Canton+Oil Pump
Old Feb 18, 2007 | 08:51 PM
Red97Z's Avatar
Default Canton+Oil Pump
What's a good high performance oil pump that will work with a canton LT1 oil pan, that's not a melling?
Old Feb 19, 2007 | 12:59 AM
1997bird's Avatar
Moroso makes one. Sealed Power/Melling/Clevite all come from the same factory.
Old Feb 19, 2007 | 08:25 AM
Red97Z's Avatar
Yeah, I've looked at the Moroso's, they're pretty pricey though. Does anyone know the appropriate pan depth for a canton pan? Is it 7.5"?
Old Feb 19, 2007 | 10:29 AM
seawolf06's Avatar
You can call Canton and see what they recommend. I would say get a Melling Select pump and a Canton pickup. If it doesn't bolt on then weld it on.
Old Feb 19, 2007 | 11:42 AM
Red97Z's Avatar
Well, there was a post on here about how Melling high volume pumps have brittle casting issues. I'm currently building a blown 800HP LT4 and need a good pump to compliment the canton pan. But thanks, I think I will call Canton.
Old Feb 19, 2007 | 02:07 PM
seawolf06's Avatar
The melling select have the thicker castings. It's the regular "M" series that have the thinner castings now.
Old Feb 19, 2007 | 05:05 PM
jmalibuss's Avatar
How much pressure are you looking to run?
Old Feb 19, 2007 | 06:31 PM
seawolf06's Avatar
Get the 25% HV Select pump from melling, don't need high pressure.
Old Feb 20, 2007 | 02:29 PM
Fire67's Avatar
I just got a Melling High Performance/Racing high volume pump... Then called canton and got the correct, bolt-on pickup. Which is pretty much garaunteed to be correct for pan depth.
Old Feb 20, 2007 | 05:51 PM
beast69camaro's Avatar
what part # did you get? I'm looking at the 10555.....what part numbers are the rest of you melling select owners using?
