electric wp? realistic numbers
The amount of load doesn't slow down the alternator. It either supplied enough juice or it doesn't.
Where did you come up with that hypothesis. Electricity has nothing to do with pully's and cranks....Well not al leats in the internal cubustion engine Alternator takes over after the car is started, ignition, stereo, power windows, power locks, all the crap on your dash, injectors, A/C.... no pully's no crank. The crank is driven by explosions in your piston chamber
For the mostpart I trust ABA383 as an intelligent honest guy who does things right so when he says he gained 9-10hp I believe him, but one dyno owner I spoke too said more like 7-8 , a dyno can easily show 3-4hp different back too back so I would not say the numbers I am posting make ABA383 wrong.
I paid too download an SAE document on the LT1 cooling system, maybe not the best $12 I ever spent but was interesting nonetheless.
With an electric WP I would not pull the belt at the strip due too demand, pulling the belt is worth about .1. Meaning for the street I will keep my mechanical and when I want that extra .1 I can pull the belt which is free and is no compromise too reliability.
--Alan
A cars alternator produces a set about of electricity (amps) at a certain rpm. Spinning it faster then that will not make it produce anymore. Just like spinning a motor faster and faster does not mean it will make more hp.
The only drag from and alternator is if you went with a heavy heavy duty one for putting out alot more amps then then stock. Like a 300amp alt or something.
That would mean there is more are more metal coils for the alt to spin through the magnets to create hp and more metal means its heavier and harder to turn.
But the alternator doesn't get harder to turn because of the power being drained from it. It either has the juice or it doesn't.
So yes, an electric water pump does put load on the engine. However it frees horsepower by not moving as much water.
The problem with water pumps is that they need to spin fast enough at IDLE so that they can keep the car cooled. That’s fine, but they don't have a variable ratio drive. What this means that at 1600 RPM (twice Idle) the pump is spinning twice the speed and using twice the energy. But the engine’s demand for coolant hasn’t increased by double. then by 6000rpm the Pump may actually not be moving water very efficiently at all (generally impeller designs that are efficient at 800 rpm are not efficient at 6000rpm) it's probably cavitating pretty badly. This is the trade off that all your belt driven accessories have. They must spin fast enough to provide adequate service at idle but that means they are probably not very efficient at 6K.
The Electric water pump solves this by always spinning at the happy medium. Faster than idle but still in it’s efficiency range.
Also Notice that on ws6.com that the dyno run with the electric WP shows that the HP difference increases directly with RPM. This is because the EWP isn't more efficiant at lower RPM that the stanrd pump, but at much higher RPM.
How an Alternator works
But 140amp alternator is still a 140am alt and doesn't get harder to turn as the load is increased.
Besides. Its not going to strain the alt anyway. Its gonna put a load on the bat first.
What's the first thing that starts getting drained when the alt goes out? The battery. If the alt is giving the charge then it gets it from the battery.
Notice that to maintain voltage in the face of increase amp draw the internal rotor’s magnetic field is increased thus increasing the magnetic forces on input shaft increase.
THANK YOU. finally someone with some electrical sense. i was looking for a link to explain this better but he summed it up for me
What is that if not response too extra LOAD?
lol
