why not 1.5rr instead of 1.6 for gm847
Originally Posted by redtail2426
as it states
im looking for facts not statements
FACT the cost to go with improved 1.6 rockers is not much higher than the cost of improved 1.5 rockers
FACT 1.6 rockers result in a more aggressive cam profile
FACT a more aggressive cam profile results in more power
4 facts hows that for you?
Originally Posted by LiENUS
FACT your stock stamped rockers CANNOT handle the lift of the new cam
EXACTLY
Originally Posted by firebird6786
i think he means on ported stock heads?
Originally Posted by -PEPE-
Especially on stock heads, even unported heads. The 1.6rr RollerRocker is a much better upgrade over the 1.5 stamped steel rocker with any cam, not just the 847 and obviously the the 1.6s will give you a more substantial lift which your future upgrades will benefit from, headers, better heads, etc.
yeah i know but stock ported heads cant flow enough to support a 1.6 rocker(for the gm847 it would be .575/.595 lt1 ported head cant support that). wouldnt you loose power?
Your choice though, your car, feel comfortable about your build, if all else at least use 1.5 roller rockers for better wear on your valvetrain.
...still recommend 1.6s though, promise you'll love em ...
So that being said I tried the 1.5 stock steel stampers, was badass, then went to 1.6s even moreso and then I bought the Comp stainless 1.7 promags and woke it up even more. I did go back to 1.6s and with stock heads it put down 373rwhp on a DynoJet. ...
Originally Posted by LT-x7
Who did you get rid of the 1.7 promags?
