Max safe compression
Old Mar 15, 2007 | 01:44 AM
95FbFormula's Avatar
Default Max safe compression
Going off the mods in my sig what is the most static compression i could run safely using P&P'd stock head castings. I am waiting on my machine shop to moch up my motor to give me the compression and deck height to see if I want to deck it or not. I was going for 11.1 but if i can push a little more I will
Old Mar 15, 2007 | 07:02 AM
Koll's Avatar
Pump gas? Whats the highest octane available in your area?
Old Mar 15, 2007 | 11:45 AM
95greenZ's Avatar
What cam are you running? Its DCR you need to worry about.
Old Mar 15, 2007 | 06:10 PM
seawolf06's Avatar
I agree. Bigger cams usually require more SCR because of the DCR they make.
Old Mar 15, 2007 | 06:14 PM
96capricemgr's Avatar
The other guys are making good points but in general I would call 11:1 LOW for a built NA LT1.
Old Mar 15, 2007 | 06:30 PM
seawolf06's Avatar
I agree. You can go to 11.5 pretty easily.
Old Mar 15, 2007 | 06:31 PM
azvforce's Avatar
You can run as high as you want, you will just have to pull more timing.
Old Mar 15, 2007 | 06:33 PM
Taubr Unit's Avatar
call me stupid but i know SCR is static compression ratio but what s DCR? And whats the differance between the 2... sorry if i jack your thread for a post or 2.
Old Mar 15, 2007 | 06:47 PM
Mortify's Avatar
dynamic compression ratio
Old Mar 15, 2007 | 07:03 PM
Taubr Unit's Avatar
so you got dynamic and static compression. Im looking to mill my heads also and learning my self about it all. Whats the differance between the 2?
Old Mar 15, 2007 | 08:02 PM
birdmaro's Avatar
dcr=percentage of the stroke after intake valve closure is compressed (because intake valve closure happens after the cylinder is sealed at bottom of stroke, and so some of the intake charge is compresses backwards by the piston at low speed)
scr
check this out
http://www.empirenet.com/pkelley2/DynamicCR.html
Old Mar 15, 2007 | 09:44 PM
It will be on pump gas. The highest we have is 94 but i will probably run 93. I dont have cam specs yet. I am waiting for my block to get done before i order the H/C. I plan on runner AI 200cc heads and street able custom cam. I believe i will shoot for 11:5 SCR I will get DCR as soon as i can
Old Mar 15, 2007 | 10:21 PM
seawolf06's Avatar
Ask whomever you're getting the cam from what SCR you should run, they will tell you what the cam was designed for.
