What is this? *PIX*
Old Mar 17, 2007 | 07:02 PM
grnmonster's Avatar
Default What is this? *PIX*
When my brother did my heads a while back he could not figure out what went to this so we just plugged it up, but ever since my car has not been running as fast, we unplugged the sensor that was in it, helped a little bit but its still slow off the line...
Old Mar 17, 2007 | 08:16 PM
Nite_Hawk's Avatar
Looks like the evap canister solenoid valve.
Old Mar 17, 2007 | 09:31 PM
Formula350's Avatar
I believe the on that angles down goes to the bottom of the TBody
Old Mar 17, 2007 | 10:10 PM
1997bird's Avatar
http://shbox.com/1/devices.htm
http://shbox.com/1/1996_evap.jpg
http://shbox.com/1/component_location_views.html
http://shbox.com/1/4th_gen_tech1.html
I found this site very helpfull!
Old Mar 17, 2007 | 11:01 PM
streetassasin's Avatar
its a hand
Old Mar 18, 2007 | 12:00 AM
LiENUS's Avatar
Originally Posted by streetassasin
its a hand
Appears to be a 5 fingered configuration too, opposable thumbs, good model. Forged would be nice though.
Old Mar 18, 2007 | 12:05 AM
Bossz28's Avatar
**** that's a good question. Definitely looks like a sensor that's vaccuum related. Shoebox might be able to help you out.
Old Mar 18, 2007 | 12:07 AM
blk97z28's Avatar
vaccum related for sure but i 'll check it out quick, try shoebox.
Old Mar 18, 2007 | 06:52 AM
the_merv's Avatar
Veteran: Air Force
It's that EVAP piece in the shoebox pics. I guess '96 and '97 have it, my '95 doesn't.
Old Mar 18, 2007 | 11:41 AM
blk97z28's Avatar
wat side did it come off of? i have something like thatbut is was ont he driver's side
Old Mar 18, 2007 | 11:48 AM
6spd97ta's Avatar
well for starters take the screw out of the rubber elbow piece. that is just a vent and with the screw in there it's not venting.
The other side (straight one) you have a screw in comes from the plastic line that runs with the fuel lines. it goes behind the throttle body and then to the evap can in the back.
