Where to get SBC heads converted?
#82
Originally Posted by 1BAD95Z
Mike you are going to have to get it to 60ft a lot harder then that to get those numbers. ever thought of like a small 50 shot coming out of the hole?
Mike
#84
Originally Posted by TwoFast4Lv
Ok first things first. The AFR heads were modified in there raw form before machining...you know the part where they cut the surfaces AND Drill all the Holes
Ever notice how the LT4 heads have the holes for LT1 gaskets also ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
ANYWAY. SO you guys are telling me I am one of the few pushing into the nines with Ported GM LT1 castings? The set that came on my car from the factory even!
I was talking to Ray and Nitro daves today. Once my heads are converted they will be true LT1 heads just like AFRs![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Like I said I would have never guessed had I not been told by four different people at AFR including Tony
Then again maybe after waiting for Over Three months for a set of 210 LT4 heads they all just decided to tell us any thing ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
If I am not mistaken, Steve Quinn ran in the nines with factory LT1 castings all motor 4 or 5 years ago.
David
#87
Jeff Stevens went 9's with factory GM castings as well...... He might still be running them i'm not sure but he went 9.48 recently......
YS trim vortech stroker LT1.....
http://para.noid.org/~lj is the link i think.... his site has ALOT of great info... same guy that sells the accelronics thingy to run big injectors with a stock PCM....
#89
9-Second Club
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Today is the first time I didn't run nines this year. Hot, humid & slick starting line. Bald spots everywhere thanks to all the street tire cars. Corvette club showed up. Could only run 10.0hs @ 133.80s. Mine has LT4 castings, so doesn't count.
#90
David
David
#91
Originally Posted by Ed Wright
Steve Quinn, Rick Abare both ran nines. LT1 castings, all motor. No bottle. Don't remember how quick Quinn was, well into the nines. (50s or 60s?) Several guys have run nines on the bottle. Spray enough of that crap in a Honda, and it will run nines.
good to know you werent hookin my buddys truck wouldnt either
#98
What I meant, guess I wasn’t clear, was the small ports. Mine are 215cc, LT1s I have seen are smaller, usually 200 or less.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
So what the hell. I HAVE the parts. Why not use them
Besides it is the best way to catch RIGHT up to the LS1 cars of the present and future
#99
steves where 196'sh when james lee did all the checking for me
