cam question
Old Mar 20, 2007 | 10:37 PM
chameleongreen97ta's Avatar
Default cam question
so i am building a new motor and i am going to run a wet 125 shot on it. I was wondering if i need to put a cam in the motor that is for nitrous or could i use any ole cam and be ok.
Old Mar 21, 2007 | 09:37 AM
sworaz's Avatar
Go custom cam!
Old Mar 21, 2007 | 12:50 PM
Razor_Blade's Avatar
A custom grind is never a bad idea, but I wouldn't get a nitrous specific grind for a 125 shot.
Old Mar 21, 2007 | 02:56 PM
street demon2k3's Avatar
x3!!! a custom grind would be better for overall driveability IMO, but since your not spraying too much concentrate on an N/A cam. I was told not to worry about nitrous cams unless you plan to spray over 200. But if you insist or find a good deal on off-the shelf cams do a quick search and you will find alot of info for your common LT1 cam questions.
Old Mar 21, 2007 | 08:01 PM
jays97 t/a's Avatar
wheres a good place for custom cams
Old Mar 21, 2007 | 08:42 PM
nimr0d's Avatar
cc306
