View Poll Results: What engine would you go with
Built LT1 (close to stock cubic inches)
3.49%
Built LT1 (big cubic inches)
14.41%
Built LT4
3.93%
LT5
5.68%
Built LS1
5.68%
LS7
29.26%
Forced induction LTx
8.30%
Forced induction LSx
29.26%
Voters: 229. You may not vote on this poll
What Engine would you get?
Old Mar 22, 2007 | 10:12 PM
1SlowFormula's Avatar
I'd have to go with a choice not on your list...
BBC, with a decent shot on top of that...
Oh wait that is what I am getting pricing on right now and will build up over the next few years...
Old Mar 22, 2007 | 11:38 PM
Captainofiron's Avatar
haha nice BBC, I would like to pics of that, especially how you get that Rat to fit in there
Old Mar 23, 2007 | 12:30 AM
germeezy1's Avatar
Now if I could get this motor to fit, then I would be in heaven. Then again it may fit in a C3!
Engine displacement: 780 cui (12.9 L)
Compression ratio: 11.5: 1
Cylinders: V / 8
Including:
-especially machined distortion free high-precision cylinder block
-individually machined high-precision crankshaft each crankshaft is fine-balanced using master weights (counter weights simulating the weights of the pistons and connecting rods which are installed later). A more exact balancing of the crankshaft is not possible!!!
-lowest crankshaft bearing tolerance Crankshaft pins are smoothed to an accuracy of 5 thousandths of a millimetre-which allows for extremely high revolution rates!!!
-super high-performance Weineck pistons
-endless piston rings (to prevent the combustion energy from bypassing the piston)
-super high-performance Weineck connecting rods
-individually machined high-performance cylinder heads All cylinder heads are prepared with a 16-knife milling head to ensure the same surface quality throughout the milling process
-individually machined high-performance valve seats. All valve seats are milled with an accuracy of up to the hundredth part of a millimetre and all three valve seat angles are milled in a single operation
-individually engineered and machined high-performance lightweight titanium valves - individually handmade, super high-performance exhaust manifolds (headers)
-super high-performance exhaust system
-super high-performance engine oil cooling system
-super high-performance gearbox oil cooling system
-super high-performance rear differential oil cooling system
-super high-performance ignition system (fully digital) with rev. limiter
Max. power: 809 kW / 1,100 hp at
7,000 rpm.
Max. torque: 1,760 Nm at 5,600 rpm.
Old Mar 23, 2007 | 12:50 AM
LMz28's Avatar
if money wasnt an issue, id want a stroked and blown ls2. have you guys seen the GTO that MTI built? its a 455 with a rear-mounted turbo. id want something like that but with TTs. a part of me wants a 396 lt1 with a nasty head and cam package though.
Old Mar 23, 2007 | 08:47 AM
Take a look at the BBC section of this message board there are a few guys that have already done it and thre are pics in the sticky's if you want to see those...
Old Mar 23, 2007 | 08:49 AM
LT1MAN's Avatar
wheres the option for the forced induction big cube LT5?
Old Mar 23, 2007 | 08:56 AM
95N20FORMULA's Avatar
Turbo 383 Stroker lt1
Old Mar 23, 2007 | 07:29 PM
onephatZ28's Avatar
Big shot of N20 on a Built LS1
Old Mar 24, 2007 | 11:22 AM
the_merv's Avatar
Originally Posted by VinR1
I'd get World Product's tall deck LSX block - 482ci, a set of their heads or some LS7s with a good port and a nice lumpy cam... 700hp shouldnt be too hard to come by with that combo
That's insane... Any links to that beast, I want to see that.
I would go with a LS7 and Cam the hell out of it.. I say that cause I already have the Wiring Harness built for a LSX Engine.
I am building a 402, wish I had some free money for that..
Old Mar 24, 2007 | 12:52 PM
-PEPE-'s Avatar
Man ya'll are all going the wrong direction...it's all about the Jet Engine Powered Honda yoh yoh ...
Old Mar 25, 2007 | 01:00 AM
Old Mar 25, 2007 | 03:24 AM
  #32
onephatZ28's Avatar
Old Mar 25, 2007 | 08:02 AM
  #33
the_merv's Avatar
WTF...
It's a Rice Cooker..
Old Mar 26, 2007 | 01:04 AM
  #34
Hark_Z's Avatar
SO hard to pick one all make your eyes light up when you picture each motor and money as no object I voted LT5 though.
Old Mar 26, 2007 | 01:11 AM
  #35
Ryota's Avatar
This is what I would be getting if money were no object!!
http://lingenfelter.com/Lingenfelter...boCorvette.htm
Old Mar 26, 2007 | 01:13 AM
  #36
the_merv's Avatar
I knew that he had to have something build with the C6, haven't seen it until now. That **** is sharp..
Old Mar 26, 2007 | 02:49 PM
  #37
Bossz28's Avatar
I voted forced induction LSX. When you say LSx that could mean LS7. God damn could you imagine a twin turbo LS7 LOL!!!!
Old Mar 26, 2007 | 03:33 PM
  #38
SLPHawk300's Avatar
stroked and blown 383...and money was an object
Old Mar 27, 2007 | 02:21 AM
  #39
BLK_Z28's Avatar
Built LS1 for me.....
Old Mar 27, 2007 | 11:35 AM
  #40
VinR1's Avatar
http://www.worldcastings.com/prods_pages/086210.htm
they're still working on the heads
