View Poll Results: What engine would you go with
Built LT1 (close to stock cubic inches)
3.49%
Built LT1 (big cubic inches)
14.41%
Built LT4
3.93%
LT5
5.68%
Built LS1
5.68%
LS7
29.26%
Forced induction LTx
8.30%
Forced induction LSx
29.26%
Voters: 229. You may not vote on this poll
What Engine would you get?
Old 03-27-2007, 11:49 AM
  #41
Ryota's Avatar
Originally Posted by Bossz28
I voted forced induction LSX. When you say LSx that could mean LS7. God damn could you imagine a twin turbo LS7 LOL!!!!
Click the LPE link I posted above, TT LS7 anyone??
Ryota is offline
Old 03-27-2007, 01:47 PM
  #42
gallardo259's Avatar
yeah, LPE did build a TT 427. ok, so it wasn't an LS7 i guess. 1038 rwhp, not bad.
gallardo259 is offline
Old 03-27-2007, 02:26 PM
  #43
transambandit's Avatar
None, ls2 with full headers/exhaust a big cam, heads, all the bolt ons and a tune, you can get all of that done for under 10k and make over 500hp easy.
transambandit is offline
Old 03-27-2007, 06:05 PM
  #44
Dragframe's Avatar
lol.. anythig can be made fast.. but you need boost to be the "fastest". Period.
Guy on turbomustang made 600+rwhp though a 9inch,big stalled t-brake 3 speed on a
chevy 350 he took out of a mid 70's truck that has all cast parts (pistons .40 over... what was in the truck).That was with junk *** smog heads that had 1.72 intake valves!!!
He put good hardware in it, cam, and put parts in the head to hold boost. This is also with twin stock GN turbos and homebuilt turbo setup with TPI injection with holley 950 commander controlling it...
Did i mention this motor has 150k on it before he beat the **** out of it? Also... did i forget the 125 shot of nitrous that he is pounding it with?
A big inch forged LSx motor with boost is gunna make ****** GOBBBBSSS of power.. not jsut 700.. lol....
Dragframe is offline
Old 03-27-2007, 06:08 PM
  #45
Dragframe's Avatar
oh... to add to my above post... He is now making 700rwhp with the same short block with just slightly better heads (our stock LT1 heads are better), different cam, upgraded turbos and only a 50 or 75 shot of nitrous....
THATS OVER 900 HP AT THE CRANK ON A STOCK CAST BOTTOM END!!!!
Motor has to be blessed by god.. lol
Old 03-27-2007, 07:08 PM
  #46
ckyconan2003's Avatar
what is an LT5?
ckyconan2003 is offline
Old 03-27-2007, 07:16 PM
  #47
germeezy1's Avatar
Its an engine after the LT-4 and before the LS1. It has 2.5 valves per cylinder and a reversed reverse flow cooling. It only came in the 96.5 Vettes and was only produced for a few hours before production started on the LS motors.
germeezy1 is offline
Old 03-27-2007, 07:33 PM
  #48
Captainofiron's Avatar
it wasnt after the LT4?? it first came out in the early 90s I think when the ZR1 vette came out
heres the wikipedia explaination:
Immediately prior to the release of the second generation Small-Block, General Motors released a largely unrelated engine which also used the LT name. The LT5 was a special engine indeed. It was an all-aluminum 349 in³ (5.7 L) small-block V8, but was entirely different from any of the other Chevrolet 350 engines. The bore and stroke were both different at 3.9 by 3.66 in (99 by 93 mm) instead of the usual 4 by 3.48 in (102 by 88 mm) and it featured a Lotus-designed 32-valve DOHC head. It was hand built by specialty engine builder, Mercury Marine. This engine produced 375 hp (280 kW) and 370 ft·lbf (502 Nm) for the 1990-1992 Corvette ZR-1 and jumped to 405 hp (302 kW) and 385 ft·lbf (522 Nm) for 1993 to its final year in 1995, thanks to cam timing changes and improvements to the engine porting. 1993 also added 4-bolt main bearing caps and an exhaust gas recirculation system. The engine was not used in any other vehicle.
oh there was four valves per cylinder
for more info check this out
http://www.zr1netregistry.com/ZR1_specs.htm
Captainofiron is offline
Old 03-27-2007, 07:43 PM
  #49
germeezy1's Avatar
read my post closer, you didn't think I was serious did you?
Old 03-27-2007, 07:47 PM
  #50
the_merv's Avatar
That 488 LSX is a beast...
the_merv is offline
Old 03-28-2007, 12:06 AM
  #51
yea, lolz you got me
the .5's on the numbers left me scratching my head for a bit, I was like no way this guy is a newb, lol
Old 03-28-2007, 09:26 AM
  #52
B4CZR2's Avatar
I would either build up the LT1 because I have two of them and just one car. No need to waste money, and with enough money you can pretty much make anything as fast as your heart desires!
I wouldn't want an LT5 either, Trying to find anything after market for them or replacement parts would probably be a pain in the ***. Its a nice motor but I wouldn't want one.
B4CZR2 is offline
Old 03-28-2007, 05:36 PM
  #53
97M6Formula's Avatar
I mean if money is no option you could do the 4v ltx heads or a lt5 or forced ls7... But if your on a little it of a budget like me I will be doing a ls2 with ls7 style heads and cam and have easy 500rwhp... However I loved my 383 lt1 torque was 350rwtq at 2600 rpms and stayed 390 from 3400- 5250
97M6Formula is offline
Old 03-28-2007, 07:29 PM
  #54
germeezy1's Avatar
You have to admit thats pretty funny
Old 03-29-2007, 12:53 AM
  #55
Dragframe's Avatar
LoL... were you stoned? jesus
Old 03-29-2007, 11:07 AM
  #56
the post actually kinda sounded like some of the newbie people who post on here with completely wrong info they got from some Ricer sites thats why I responded, and to answer ckyconan2003's question
Old 03-29-2007, 10:45 PM
  #57
Irish350's Avatar
man thats tough... id like a number of those engines... lol
my top 5 are lt5, big cube lt1, big cube lsx, FI lt/ls
EDIT: DOH!.... didnt see the ls7 option... i guess ill make a top 6
Irish350 is offline
Old 03-31-2007, 10:03 AM
  #58
96mikez28's Avatar
Bbc
96mikez28 is offline
Old 04-01-2007, 07:47 AM
  #59
smooveZ's Avatar
Originally Posted by -PEPE-
oh hellz yeah!! I want to see that in a 97 ..be a tight fit.
Thomas Stricklin, the Camaro Brand Manager from Ecklers Camaro has a black 94 Z with a B.B.454. It`s freakin awesome!! Also Super Chevy magazine January 1999 the cover car is a orange with white stripes 94 Z with a 502B.B.,Turbo 400 trans.
smooveZ is offline
Old 04-01-2007, 11:38 AM
  #60
germeezy1's Avatar
The 572 Donovan BBC in the ZL-1 Camaro is a pretty amazing engine to shove into an F-body!
Quick Reply: What Engine would you get?
