Cheap Opti Strikes again
Personally I have had great results with the stock piece and last heads and cam swap I simply replaced the 70K mile cap and rotor on a stock opti with fresh pieces from MSD. Replaced the stock pieces because of milage and because it was apart not because they were faulty.
The brown you see is the epoxy you see from the outside on the front! Completly burned the internal wire through the black plastic. Anyways, an O'Reilly's cap and rotor fixed the problem without spending the big $$$ on a complete opti. O'Reilly's webpage The funny thing? The car had 99,998 miles on it when I changed it out, I bullshit you not. Good luck with yours. Opti's are a fickle beast at best, sometimes you can never tell what the hell they're going to do.
Video of the bad opti, at least it sounded cool -->like a huge cam
