Lt1 fuel system pics.
Old Mar 23, 2007 | 02:55 AM
colts95ta's Avatar
Default Lt1 fuel system pics.
I was wanting to see some pics of peoples set ups of there fuel system from tank to injectors for some ideas.Thanks.
Old Mar 23, 2007 | 03:28 AM
Speed Density's Avatar
hashtagBMW
Thats all i have right now.
Old Mar 23, 2007 | 08:00 AM
jldak318's Avatar
here is a couple of mine
Old Mar 23, 2007 | 11:26 AM
Ru2slo_99's Avatar
I will try to get some this weekend.
Old Mar 23, 2007 | 11:35 AM
Red97Z's Avatar
Where's the best place to tap into the stock tank for a sumped fuel system? Feed/Return?
Old Mar 23, 2007 | 11:59 AM
hashtagBMW
Bottom right.
Tony.
Old Mar 23, 2007 | 01:09 PM
colts95ta's Avatar
In the stock tank there is a plastic sump thing right in the center at the very back when the tank is mounted. You have to pop it out when you weld on it. They make the stock in tank pump just about suck the tank dry that is why it is there. I was going to actually weld a sump on the stock tank rather just putting a outlet. I would think the returning up top would also be the best idea. Thanks for the pics. I would like to see some of the stock fuel railed high hp cars.
Old Mar 23, 2007 | 01:32 PM
Tony Shepherd's Avatar
I will try to get some pics of my sumped stock tank.
Old Mar 23, 2007 | 01:47 PM
OutlawZ's Avatar
14 gallon nasty tank, fuel labs filters, weldon 900a, 12AN feed out the sump into 10AN all the way to the front, fuel labs y-block 10AN to dual 8AN and twin 8's will feed the back of the rails. 180 degree 8's are not shown off the front of the rails feeding a fuel labs regulator with 6AN back to the tank... 50 lb injectors...
Old Mar 23, 2007 | 04:20 PM
FASTFATBOY's Avatar
Some of mine are in this post.
https://ls1tech.com/forums/drag-racing-tech/378024-finished-minitub-pics.html
David
Old Mar 23, 2007 | 09:01 PM
the_merv's Avatar
Veteran: Air Force
Some of you guys aren't playing around...
Old Mar 23, 2007 | 09:26 PM
LT1Falcon's Avatar
thats what i was thinkin. u guys must be runnin some good numbers to need fuel systems like these
Old Mar 23, 2007 | 10:40 PM
OutlawZ's Avatar
fuel system and oiling system is two places you don't want to skimp.....
My fuel system would most likely be good for up to 1500hp with just an injector change..... I'm setup to make about 1000hp on nitrous....
Old Mar 23, 2007 | 10:42 PM
JUICED96Z
Guest
Posts: n/a
Outlaw, whats retail on that sick setup? Im looking at 900hp at the crank on the bottle this year
Old Mar 24, 2007 | 01:48 AM
OutlawZ's Avatar
Talk to Nate at Nasty Performance for all the details but i think my shipped price for everything (not injectors) was like 2100-2200..... Tank, regulator, pump, filters, all the fittings, y-block and 10AN, 8AN, 6AN line in different lengths. The 10AN was long like 15' or 20' as well as the 6AN and the 8AN was like 10' cuz i only need it for the y-block to the rails and rails to regulator....
Good thing about buying from Nate other than the great customer service and quality is not having to pick and piece together fittings. YOu tell him how you plan to set it up and he does all the fitting shopping for you... and puts together a document showing in what sequence all your fittings go from tank to rails and rails back to tank one by one....
Old Mar 24, 2007 | 02:46 AM
hashtagBMW
Nate is a great guy to talk with about fueling. He set me up with most of my fuel stuff for the old setup.
Tony.
Old Mar 24, 2007 | 03:08 AM
-PEPE-'s Avatar
Outlaw, sharp setup, love the clean firewall penetrations, very sharp. I've talked to Nasty about a full kit front to rear tied to a SuperVic, about $1800 quote. I have an AEro1000, Aero billet filter, about 75% of the fittings and line (AN10), just need a Fuel Pressure Reg, Nasty tank and after seeing your setup probably quite a bit more AN line and fittings. Again sharp setup you have there.
Old Mar 24, 2007 | 06:11 AM
LT1Falcon's Avatar
cant you do all this with just a better fuel pump? whats the point in the fuel cell and braided hoses. is it a class rule, does it flow better, or am i missing something here?
Old Mar 24, 2007 | 09:42 AM
-PEPE-'s Avatar
Well many run a good intank pump and still run braided with a decent fuel press reg and are good to for high quite some time. It's when you get to a point where you want to insure your investment by not "going-lean" on the top end with a poweradder, nitrous, turbo, SC or even a big all motor setup, the better fuel system maintains the fuel pressures your system requires throughout the full powerband without faltering or having enough either pressure or being able to regulate it right. The big AN lines and fittings are for the highflowing setups, the s/m tanks allow us to run like Wolfe Racing rear sway 4links Vs. bullshit swaybars, these tanks also have the provisions to bolt up the hardware like external fuel pumps, hardware mounts for billet filters and they are pre-sumped which is a plus Vs. going through the top of the tank.
Old Mar 24, 2007 | 11:29 AM
LT1Falcon's Avatar
wow, i didnt know fuel flow was such a concern for you guys, makes sense now
