Where does this wire go...
Old Mar 25, 2007 | 07:32 PM
sworaz's Avatar
Default Where does this wire go...
Like above, anyone have any ideas where this wire plugs in to? It's made with 3 wires 2 red and 1 black, one of the red ones goes into the fuse/relay box. Also my fans don't turn on at all, not when the temp is high or when the AC is on, hope this wire has something to do with that?
Old Mar 25, 2007 | 07:54 PM
Speed Density's Avatar
hashtagBMW
Looks like the AIR pump sensor.
I may be wrong though.
TOny.
Old Mar 25, 2007 | 07:58 PM
transam5.7lt1's Avatar
I don't think it has anything to do with your fans, my sisters 1997 firebird has that same wire unhooked and I didn't find where to plug it.
Old Mar 25, 2007 | 08:06 PM
the_merv's Avatar
Veteran: Air Force
Where does it come from.. The MAF has that same end, but you probably have that plugged in already. My Fans went out also the other day, I hard wired them as constant run.
Old Mar 25, 2007 | 08:12 PM
Ralls's Avatar
AIR pump connector.
Old Mar 25, 2007 | 08:14 PM
i420tom's Avatar
check your fan relays usually the problem if happens suddenly. put your hand on it and feel if it clicks while someone else turns the car and the ac on.
i had a fuel pump relay go out on me before in my mustang and it went out an unusal way. I shut the car off and while walking around it i heard that the pump was still running!!! with keys in my hand!!!
was a bad day for me. ripped my whole mustang apart looking foir the damn relay.
6 hours later and still no luck i got pissed and punched my driver seat as hard as i could annd the ****** finally shut off. the damn relay was mounted directly uner the drivers seat sticking up thru the carpet.
little off topic but i thought it may make one of yous laugh.
Old Mar 25, 2007 | 09:04 PM
indirocz28's Avatar
In the back of your manifold- on that driver side- see if there is a little box/ solenoid hanging w/ 2 elbows on it. If not- im pretty sure it is the AIR pump connector. - i'd say its nothing to worry about..
Old Mar 25, 2007 | 09:15 PM
fergymoto's Avatar
Definitely the AIR pump pigtail.
9formula4's Avatar
see if you can find it on this clickable harness page
http://shbox.com/1/harness.htm
Old Mar 25, 2007 | 09:22 PM
IllusionalTA's Avatar
clean that car!!!
I'll second the air pump plug..
Old Mar 25, 2007 | 09:27 PM
jd783's Avatar
TOny.
thats what i thought also
check your temp sensor on your water pump if you unplug it with the engine running your fans should turn on if they do that sensor is bad
Old Mar 25, 2007 | 09:49 PM
sworaz's Avatar
Thanks alot guys i'll definitely check that air pump. Clean the car....
Old Mar 26, 2007 | 09:32 AM
Ntimid8r7's Avatar
Yep! Ill 3rd and 4th the AIR pump plug seeing as how it looks like all the plumbing for it is gone...
Old Mar 26, 2007 | 10:57 AM
PunishedU's Avatar
My car has always had that unplugged as well and I just never really looked around for it. Now I may have too though.
