LE2/LE1 Emissions Cam Dyno Results
I just like to give a special thanks to Lloyd Elliot for flat-out nailing the combo, to Dave at D&F Performance for doing a superb job with the SB and engine assembly and to Bryan Herter for his tuning abilities. We picked up almost 20hp on the dyno. Well Done!!
Will get her to the track shortly.
![](http://i24.photobucket.com/albums/c44/drewg23/DynoLT1Final.jpg)
These are corrected numbers from the chassis dyno. There is roughly 16% drivetrain loss on a 6M F-body with the stock 7.5" rear. Therefore, these numbers would put it at about 460 HP at the flywheel.
Your graph says STD correction factor on the sides. I was just curious what it made with SAE numbers that more people can relate too. What was the weather like the day you made the pulls (temp/pressure etc)?
It doesn't really matter, I was just curious if you had those numbers. Congrats.
