O2 Sensors...need help!
Old Mar 27, 2007 | 12:26 PM
383_LT1_1295's Avatar
Default O2 Sensors...need help!
OKay...the SES light came on in my 94 z28 a4...so i had the codes pulled and it said it was the o2 sensors..so i go and get 2 new ones...the one on the drivers side was a peice of cake...but the passenger side was a different story..could anybody give me some advice on how to get the passenger side sensor out easier...thanks alot guys.
Old Mar 27, 2007 | 01:36 PM
James Montigny's Avatar
What's the problem, just not turning when you put the wrench on it?
It's easiest when it's warm. Just don't burn your arms on the pipes.
PBBlaster is your friend for tough bolts
http://www.blasterchemical.com/store...m?Product_ID=1
Get it any any local parts store for $5 or so.
Spray it on, let it soak in and the O2 should come right out.
Old Mar 27, 2007 | 10:24 PM
NovaTodd's Avatar
Drive the car and get the pipes warm. Spray with favorite lube (PB, WD40, ect) and let sit overnight. Repeat as required.
If that does not work, heat with a torch and melt candle wax into the threads. Let cool and it should break the sensor free.
These always seem to work for me. But we don't get the rust you guys back east do.
Old Mar 28, 2007 | 05:46 PM
well the biggest problem is gettin a wrench to it in the first place....talk about a cramped engine bay
Old Mar 28, 2007 | 05:50 PM
LTs make that so much easier
Old Mar 28, 2007 | 06:41 PM
borninatransam's Avatar
i used like 2 universal joints and the specialty socket and it was pretty quick in and out.
Old Mar 28, 2007 | 11:02 PM
NovaTodd's Avatar
Wait until you go to install headers or change the plugs.
I don't remeber the O2 sensors being that difficult to get to (at least compared to some other items. Now you may only be able to get about 1/8 of a turn before you have to flip the wrench over for the next 1/8th of a turn.
Old Mar 28, 2007 | 11:30 PM
Bossz28's Avatar
yeah if that doesn't work there's always the hot wrench lol!
Old Apr 2, 2007 | 10:38 AM
ok guys i got it out...thanks for your suggestions...i really appreciate it...and i toatally see what you mean about changine the spark plugs or putting hearders on..which i am about to do...once again thanks alot.
