no point for a 4 bolt lt1?!?!
Old Mar 27, 2007 | 10:33 PM
Taubr Unit's Avatar
Default no point for a 4 bolt lt1?!?!
I found this on a turbo forum and i quote.....
"""I am starting my winter upgrades to the bottom end to support much higher boost levels. After consulting a few race shops that I respect I was interested to hear that they really do not see much need for splayed caps on the LT1 due to the webbing and block strength.
SO post up your opinions. Has anyone really found the limit of the 4 bolt caps on the LT1? Please dont just speculate, we all know what the splayed caps are supposed to do."""
Old Mar 27, 2007 | 10:46 PM
siniSSter's Avatar
Your gonna hear diffrent responses from diffrent builders..my opinion 4-bolt
Old Mar 27, 2007 | 10:52 PM
Gun5's Avatar
i got 2 bolt w/ ARP
Z8'S's Avatar
My last engine was a factory 4 bolt LT1 ran 8.9's @3450 lbs.
Old Mar 27, 2007 | 10:54 PM
95FbFormula's Avatar
I would think the 4-bolt would be better if you are going to spin high rpms or push a lot of boost if not i thyink the 2bolt would be fine I am keeping mine 2-bolt with ARP main studs.
Old Mar 28, 2007 | 02:32 AM
94 F-body's Avatar
I was told that the 4 bolt mains could hold higher HP ratings than a 2 bolt, about 1,100 HP on 2 bolt to 1,300 HP on 4 bolt, but...
Old Mar 28, 2007 | 02:45 AM
Speed Density's Avatar
hashtagBMW
Im going to go out on a limb and say that those 'shops' saying that a 4 bolt block is not needed are most likley GEN 1 guys. Guys that have been building SBC's for years and have seen results.
The older SBC blocks are strong, and many of them can handle gobbs of power on just a studded 2 bolt block. The LT1 is not totaly an SBC block and if you plan on big power 4 bolt is almost the only way to go.
Tony.
Old Mar 28, 2007 | 06:58 AM
IllusionalTA's Avatar
There are guy's making 550-600 on studded 2 bolt's all day long... especially in the late model stuff they do around here.. I would do a splayed cap or if you can find a factory 4 bolt do that...
Old Mar 28, 2007 | 07:08 AM
bmccrary's Avatar
I feel that a 4 bolt is just a security thing on these motors, its there just to help prevent something from happening. Heck if your going to build a motor that will be put thorugh its paces alot, why not do it right?
-bryan
Old Mar 28, 2007 | 09:06 AM
96SCTA's Avatar
i ran the stock 2bolt with apr studs... Heads and vortech supercharager.
After 2 years of running around like that on 9lbs of boost.. when i tore my motor down to build the 383 i found chaffing betweend the caps and the blocks. Which means their was movement. Needless to say now i run 4bolt splayed..
Hope this helps some
Micah
Old Mar 28, 2007 | 10:06 AM
otherwhitemeat's Avatar
Micah
YES YES YES .....This is way you 4 bolt or splay a block so it doesn't flex! Also all that shifting will wear it out faster.
Old Mar 28, 2007 | 10:22 AM
Hot94Z28's Avatar
If I drop all that coin I would just feel better about 4 bolt. Then I would not feel so bad about driving the **** out of it.
Old Mar 28, 2007 | 10:26 AM
The Big Show's Avatar
This quote sums it allllll up...
Old Mar 28, 2007 | 10:36 AM
Untamed's Avatar
How would you find out if you have a 2 bolt or 4 bolt?
Old Mar 28, 2007 | 10:38 AM
396D1SS's Avatar
pull the oil pan off
Old Mar 28, 2007 | 10:52 AM
Are you serious?!?!
Old Mar 28, 2007 | 11:01 AM
PunishedU's Avatar
Thats kinda what I was thinking. If you are gonna spend the money for a high powered rebuild, just for the added insurance, splay it. Its not like it will hurt anything, and Id rather spend the few hundred or whatever now and feel safe and not worry about a 2 bolt.
Old Mar 28, 2007 | 11:47 AM
firehawk408's Avatar
I'm going to semi-hijack this thread and ask if the step has been made to splay the block and you are using billet rods, have plans to spray maybe 150 would it be stupid to use a cast stroker crank instead of a forged unit?
Old Mar 28, 2007 | 11:50 AM
94strokedz's Avatar
My 2 bolt didnt hold up at all. I only put 402 to the tires while spraying it, and the mains were completely wiped out, caps moved so much they actually scarred themselves at the mating surfaces.
Old Mar 28, 2007 | 12:06 PM
Why would you spend the money or billet rods and not get a forged crank?
With the cost of forged cranks these days it makes no sense to go cast unless you are just reusing what you already have. I bought my 4340 forged crank brand new from a place in Dallas, Tx. for under 300 bucks a few years ago and stuff is even cheaper now. Granted better cranks (already profiled) are going to cost more but for a cheap build there is no reason you have to use a cast crank unless you just want to.
