Anyone get a Carbed LT1 intake manifold..
Originally Posted by chromeplated500
Anyone get a carbed setup for an Lt1 and do you like it and where did you get it??
Cost?
Thanks in advance.
Cost?
Thanks in advance.
Well I've got an LT1 and an old corvette, I want the power, but i was also liking the carbed look which would be easier. theres not alot of room in the car for all the pcm and sensor crap... but it can be done..
An LT1 without it's injection is just another smallblock. Would be more effient money wise to just stick with a gen 1 if using a carb.
Power wise the heads are the biggest advantage the LT1 has and the Vortec heads which are dirt cheap for gen 1s match them pretty well or there is an endless array of aftermarket choices.
i agree
thanks
there was a guy with a black trans am with a gen 1, and the holley scoop sticking outta the hood. I'm considering using a carb setup, because i cant afford dfi. however, there is better power in an lt1 with fuel injection.
parts are 1/3rd the cost for gen 1 motors, but headers and motor mounts, k-members, have to be dealt with.
Cost?
Thanks in advance.
Cost?
Thanks in advance.
We machine the Edelbrock EFI manifold to work with the LT1 heads. You still have fuel injection but you get rid of the LT1-4 manifold, which is a major restriction on the LT1-4 motor.
I have done many of these manifolds; I have guys putting 550HP to the wheels with this set up. If you would like to see what it looks like check out my website www.PortPros.com
Click on Tony’s motor and you'll see the set up. Great thing about it you can run your injectors, the manifold comes with the fuel rails and hardware. We machine it to fit your LT1 heads, we also port it and can plug the distributor hole and thermostat housing if you want. We can also remove the thermostat housing. It's the best way to make big power, get rid of that LT1 manifold.
If you would like to give me a call I'd be happy to go over the details with you.
Harold
512-257-0222
Port Pros LLC
Originally Posted by vtec
you can make an LT1 turn 7,000+ rpms cheaper with a carb than you can with fuel injection.
Harold
512-257-0222
Port Pros LLC
Harold
512-257-0222
Port Pros LLC
I hear good things about your work... but I can't even get an idea if I want to spend my money with you the way the site's set up.
