Shootin flames????
Old Apr 1, 2007 | 05:04 PM
wag7079's Avatar
Default Shootin flames????
My car started hesitating at about two weeks ago. now when it gets to about 4500 it misses and shoots flames until i let off. 90k miles on car. all original down to plugs and wires. only mods pcmforless tune, 373.
Old Apr 1, 2007 | 05:56 PM
LT1Falcon's Avatar
sounds like its in the ignitions (opti, plugs, wires). also i dont know what you did to your tune, but when you see flames, it generally implies that its running too rich.
Old Apr 1, 2007 | 06:04 PM
Captainofiron's Avatar
maybe you accidentally did the Ford Super Duty mod, lol
usually fire from the exhaust is timing mis adjustment or fuel in the exhaust
Old Apr 1, 2007 | 06:21 PM
Gun5's Avatar
or **** poor rich i did it before was ******* awsome.. before i rebuilt the motor
but im sure if i put a flame kit on my exhaust tip i could still burn it up cuz no emissions and ****
Old Apr 1, 2007 | 07:10 PM
wag7079's Avatar
I don't think its the tune it hasn't been touched in months
Old Apr 1, 2007 | 08:23 PM
LT1Falcon's Avatar
this guy must be a sailor
Old Apr 1, 2007 | 10:34 PM
Summit2345's Avatar
Bump for a friend!
Old Apr 5, 2007 | 04:54 PM
wag7079's Avatar
Nobody has any clues as to what it may be
Old Apr 5, 2007 | 11:21 PM
Formula350's Avatar
Plugs, wires, cap, rotor and coil is what I'd do. 90K on all of them, get it done now. Yet, since you're going to have the waterpump off ANYWAYS you might as well just replace it and the opti. When the pump goes, it's going to spray water on your opti and toast it to heh.
Don't feel bad, only one person bothered to pony up any info on my problem. You got 10x the replies I did :\ G/L to ya.
Old Apr 5, 2007 | 11:53 PM
wag7079's Avatar
thanks
Old Apr 6, 2007 | 02:04 AM
the_merv's Avatar
Veteran: Air Force
Mine did it earlier tonight bouncing of of the Limiter going into 3rd. Engine stalled out, we got it on Video.
Old Apr 6, 2007 | 07:49 AM
The stunningman's Avatar
Replace the plugs and wires. If your bucks up go into the opti. Are you showing any codes? Engine misfire code if it was 96 up would pin point the cylinder.
Old Apr 7, 2007 | 01:28 PM
wag7079's Avatar
no codes but its a 95 so it probably wont throw any. since I've had time to play with i found out weather determines when it does it. moisture or wet out side it does horribly. if its been dry for a couple days shell go to rev limit just as smooth as ever. Also last week it wouldn't start so looked under the hood and my coil wire to opti was laying there and coil was arching on maf sensor.
thanks for the info btw.
