Serious electrical issues
Old Apr 3, 2007 | 11:46 AM
69Cougar's Avatar
Default Serious electrical issues
Alright, this may have been my worst stroke of luck ever.
I had an interview today, I pretty much had the job (Sears Auto Tech), all I had to do was show up on time. And my car wouldn't start. I called them and explained, and they basically said too bad too sad...
So, rather than throw a hissy-fit, I want to figure out why my car won't start.
Here is the deal. My battery is not dead. My lights and radio all work just fine. But when I press the clutch in and turn the key, car is dead as a doornail. No power. Nothing.
I just put a new starter in in December.
It does not crank. It does not turn over. Nothing. I sat there for 30 minutes trying to get it to start, and it wouldn't. Eventually, I got the car to crank 3 times in a row, but it never actually started, and than it was dead once more.
The car has been FINE. No signs of trouble. I can not for the life of me figure this out. Any help would be grand.
Old Apr 3, 2007 | 03:39 PM
69Cougar's Avatar
Anyone? Hints, tips? I am at a loss..
Old Apr 3, 2007 | 04:23 PM
MEAN LT1's Avatar
Is your security light blinking when you try and start it?.
Old Apr 3, 2007 | 04:48 PM
69Cougar's Avatar
Negative. However, my key is definately worn...perhaps that could be part of the issue?
Old Apr 4, 2007 | 01:55 AM
Andrews_Motorsports's Avatar
This may sound stupid, but are your battery posts tightened down all the way? I have had this happen with several of my f-bodys. All of the electronics in the car will work just fine but the battery post is just a hair too loose for the car to start. You might also try cleaning your battery posts.
Old Apr 4, 2007 | 09:54 AM
69Cougar's Avatar
Well I got the car to start cranking, but now it will not start!
I have fuel pressure, and the car cranks like normal...and if I am quiock enough I can get ONE 'rev' if i tap the gas before it dies...
Solenoid? PCM? Opti? (oh god please not the opti..)
Help...I have a ton of job interviews this week and my friends are very quickly gonna get tired from hauling me around.
Old Apr 4, 2007 | 10:16 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Your car hates you because your handle here is 69Cougar.
I would check ALL the ground points including the battery ground on the side of the block.
Old Apr 4, 2007 | 12:12 PM
69Cougar's Avatar
But but...all the good names are already taken!
And I will check the grounds.
