LT1 MAF Problem
Old Apr 4, 2007 | 08:18 PM
siniSSter's Avatar
Default LT1 MAF Problem
I just got my computer back from PCMForLess, car starts up fine, but idles a bit rough. The car is running lean, and once it reaches operating temp it starts to studder all through the RPM. I put a scanner to it, and I'm getting a P0100 code. I changed MAF, but still no luck. Just wondering if anyone has had this kind of problem before. Please give my your opinion on this issue.
Old Apr 4, 2007 | 08:24 PM
dhdenney's Avatar
Are you sure it's P0100? My book only shows MAF codes to be P0101-P0103.
Old Apr 4, 2007 | 08:26 PM
LT14MULAWS-6's Avatar
hmm im not sure if this helps but i knew a guy who ram his car for months without a MAF, lol he ran directly off the TB, no filter no nothing, lol i tried to tell him, but the car still ran fine, MAF might not be the problem, lol well obviously its not the problem if u replaced it
Old Apr 4, 2007 | 08:27 PM
siniSSter's Avatar
Yup, positive. Is states MAF or VAF Circuit Malfunction. The car has a OBD2 PCM, and I've tried not using the MAF, and the car won't turn on.
Old Apr 4, 2007 | 08:28 PM
dhdenney's Avatar
Well I guess I should have ask what year first.
Old Apr 4, 2007 | 08:31 PM
siniSSter's Avatar
Its a 97 383 stroker
Old Apr 4, 2007 | 08:35 PM
but realisticly the MAF will not make the car not start, throw a pressure guage on the rail, than maybe look into an ICM or something of that nature that would couse a no spark condition. Im not saying you are not having a MAF problem i am only saying thats not why your car isnt running
Old Apr 4, 2007 | 08:42 PM
siniSSter's Avatar
I have a fuel pressure guage inside the car, reads just fine @ 45 psi with the vaccum off. The ICM has been replaced about 2 months ago and recently relocated to read a denser temp. The MAF not starting the car is not a big issue, since its never started without the MAF, even when it was stock. I've even check the MAF wiring and pigtail, and seem to been in good condition. I just rebuilt my stroker, and all sensors were replaced on this new engine.
Old Apr 4, 2007 | 09:04 PM
dhdenney's Avatar
Was it a new MAF or a used one? A new one I am assuming. Have you tried resetting the PCM by removing the negative battery cable?
Old Apr 4, 2007 | 11:22 PM
REDHOtTransAM's Avatar
check your fuses...I was pulling the same code for months and getting shitty gas mileage. changed the maf didn't work, the wiring...checked the fuse and that was the problem. it was keeping the maf, map and o2's from reading correctly
Old Apr 4, 2007 | 11:36 PM
siniSSter's Avatar
Hmm, never heard that one before. I'll do that. Do you recall which one it was exactly?
Old Apr 5, 2007 | 02:24 AM
siniSSter's Avatar
I can't believe it, Thanks REDHOtTransAM...that was it. I checked all my fuses and finally got to the fuse box in the engine bay, there is a fuse that says "Engine Sensor" 20 amp. Pulled it out, and blown. You got me out of a huge dillemma.
Old Apr 5, 2007 | 11:42 AM
street demon2k3's Avatar
Mark, does that mean the car's ready for Friday night?
Old Apr 5, 2007 | 11:45 AM
siniSSter's Avatar
Yes sir, hopefully I can make a few passes.
Old Apr 5, 2007 | 12:26 PM
Bad ***, now we just need Randy to go. We'll see who's XFI cammed car is faster, yes sir it will be fun!!!! Oh and BTW I think Super Mario f***ed the Princess to death in your avatar .
