trans removal
Old Apr 10, 2007 | 11:31 AM
fordeater's Avatar
Default trans removal
ok so Im trying to get this A4 out of my '93 Z and I cannot get those top bolts out, how do you guys do it, or do you guys have any tricks. Any help would be greatly appreciated. Thanks, Kevin
Old Apr 10, 2007 | 11:34 AM
camzaro28's Avatar
Haha, dont worry you are not alone on that one.
It took a couple extensions and swivels to get it out, MUST have patience!
GL
Old Apr 10, 2007 | 11:42 AM
Speed Density's Avatar
hashtagBMW
Extensions are key.
I would also recomend dropping the *** end of the trans down a bit. It will pull the top bellhousing bolts down and you can almost get your whole arm up there to do the wrenching.
Good Luck
Tony.
Old Apr 10, 2007 | 12:06 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Lower down the tranny cross member, have a jack and a block of wood underneath, get a LONG extension and carfully work the bolts out, make sure the flywheel bolts are out too.
Old Apr 11, 2007 | 02:04 AM
LT1's Avatar
LT1
you mean torque converter bolts
Old Apr 11, 2007 | 02:12 AM
LT1's Avatar
LT1
To get that top left bolt use shallow 9/16 thin wall swivel socket with a really long extention, make sure the rear of the trans is hanging all the way down with the cross member completely unbolted, trans cooler line's off, harness unplugged and anything thats attached to the trans.
Old Apr 11, 2007 | 03:25 AM
Junk LT1's Avatar
i did mine from the top of the motor with a ratcheting wrench.
Old Apr 11, 2007 | 03:53 AM
smoknta's Avatar
A 24" extension and a universal joint did the trick for me. I'm having a hard time getting the middle one on the drivers side though. I guess I'll go buy another universal joint and try them both.
Old Apr 11, 2007 | 06:16 AM
Internet Mechanic
Yea, fly to converter, not fly to crank, miss typed. Also make sure the coolant lines are un hooked, the dip stick tube is out, the harness is un hooked and the shifter cable is unhooked.
Old Apr 11, 2007 | 09:18 AM
fordeater's Avatar
thanks alot guys, im gonna try at it again.
Old Apr 11, 2007 | 09:47 PM
VIPER EATER's Avatar
just did mine and like he said use a long extension and on the bolt that hes talking about i just used a wrench to get it out
Old Apr 12, 2007 | 12:18 AM
the_merv's Avatar
Veteran: Air Force
That Drivers side bolt was a bitch..I rounded it off and had to get my round-out kit on that one. I dropped the whole K-member to make everything easier.
Old Apr 12, 2007 | 07:08 AM
grn95t/a's Avatar
i just used a long pry bar to bend the floorpan up abit and the swivel socket with a 48" extension worked great! had to use some rtv to hold the bolt in the socket to put it back in though. couldn't fit my big *** hand up there!
Old Apr 12, 2007 | 09:12 AM
smoknta's Avatar
Thats funny...thats exactly what I had to do to get it out. I dont remember it being that hard a couple of years ago, but this time it was not coperating.
Old Apr 12, 2007 | 09:25 AM
Internet Mechanic
Thats a great tip, I used it for a bolt that was at a weird downward angle which I couldnt get my hands down there. This was for the EGR tube on my dynatech headers.
