Fuel Injector Question...
Being that your installing a hot-cam kit (which should be stretching the injectors a little already) and you need the injectors to supply extra fueling when spraying, Id say that you SHOULD need bigger injectors.
The mileage really has nothing to do with whether or not you need larger ones...
Talk to the nitrous kit manufacturer for an injector recommendation.
Also, you really should have it tuned for the spray, as the pcm needs to control the fueling and I doubt a stock file is up to the task.
It would be foolish to run a dry shot on stock injectors, not because of sizing or milage or anything but rather because a dry shot injects the fuel by jacking the pressure making the injectors act much larger, not by messing with the pcm as stated above, that can be done with aftermarket management but is not the case here. The stock injectors fail closed if overpressurized which would be instant death for the motor. Other injectors like the SVOs stick OPEN if overpressurized and are capable of handling more pressure to begin with.
Work with your tuner to select an appropriate injector size... yes, you should get the engine tuned ON A DYNO with the hotcam for best results. It's also CRITICAL to monitor fuel pressure at WOT under load, whatever size injectors you select, to make sure your pump can maintain pressure at the new required volume of fuel flow... and IMHO, you need a fuel pressure safety switch to kill the nitrous if fuel pressure drops too much, set around 35-40 psi active ALL the time
And FWIW, LS1 injectors run at 58 psi, so at 42.5 they flow much less. 28 pph LS1 ijectors flow about 22 pph on an LT1.
96capricemgr- How does a dry nitrous kit cause an increase in fuel pressure? Ive never installed a dry kit, but Im almost positive that Ive seen lots of them that spray directly through the MAF, causing the PCM to add fuel.
95N2OFormula- You need to do some homework guy. You cant expect people to just tell you absolutely everything you need to know. Talk with the N2O kit manufacturer, AND talk to a experienced tuner for suggestions.
I guess some kits spray thru the MAF and trick the pcm into adding fuel that way.
If someone would care to tell me the BSFC and the target HP (meaning expected flywheel HP on the shot) Id be glad to run the numbers and provide an injector recommendation.
