Beehive Valve Spring Info
Since I was upgrading to 1.65 RRs I was changing out my valve springs, and I thought I would upgrade to some Beehives, well after holding for a while and calling back a few times, I finally talked to a guy on Cam Help. Turns out that with a stock cam with 1.6 or 1.65 ratio rockers the 26918-16 beehive spring will drop down directly onto the stock spring seat and require no machining or shims.
So if you want to get Beehives, you need:
26918-16 beehive valve springs
795-16 spring retainers
611-16 valve locks
edited for your safety
If that's not what you were asking, heh whoops >_>
the tools your need to change it on the car is the on car valve spring compressor, get a good one, not a cheapo AZ rental, and you can do it 2 valves at a time, rotating the piston to TDC so the valves wont fall, or you can do what Formula350 said and get the compressor tool to push the valves up, both ways are good, you just need a compressor for the second method
613-16 These are the standard 10 degree locks without the recessions for the lash cap like the 611 locks have which we don't use. It might not make much difference, but then again it might. I'd get the 613 locks.
614-16 These locks are 10 degree that add .050" to the install height. These are necessary to get the recommended 1.8" install height with the 918 spring on a LT1 head. Can only be use with 10 degree retainers.
4705-16 These are the beehive spring locators. You should NOT use the stock locators with aftermarket springs. It just isn't wise and they don't cost that much.
and the stock seats can be used because those 918s drop right down on them
I see where you're coming from with the space issue and running a hose. You can get u-joint's for air though, so you can go in at a 90º angle.
You should be able to get TDC on each cyl no prob. 18436572
I'm sure I'd get frustrated though lol AND, imho, the PRC or Patriot dual springs are FAR better, and include the seats, 10 degree titanium retainers, and locks.
Do more research before deciding the beehive 918s are the shiznit... you might wind up deciding they are just the shiz if you get the bad ones
