Update on the swap..
Old Apr 13, 2007 | 08:19 PM
the_merv's Avatar
Default Update on the swap..
This is going to be a nasty little setup.. it's not LTX based, but it will be stomping the shiiit out of LS1 cars, I have a couple around here to kill...
I have done everything myself so far, including the Wiring Harness, and all the necessary car modifications. I still have a few left..
Starting to get the good stuff in now..fells like Christmas until I remembered that I paid for it.
Completely Assembled L76 Intake with LS2 Fuel Rails and LS2 Injectors, LS2 FRC's
Holley 90mm Throttle Body
L92 Heads, bare. I have all the Valves, I also got the offset Rockers, and the Rocker Pedistals. I am buying good Springs, Retainers, all that stuff.
6.0l Truck Iron Block.
I still have to get the Rotating Assembly, it is all Eagle Forged, 4" Crank and 6.125" Rods with Mahle 4.000" -12cc reliefed Pistons. Then the Timing Chain, and the little stuff from there.
It will be a beast..
Old Apr 13, 2007 | 09:18 PM
95FbFormula's Avatar
Looks like its gonna be a monster can't wait to see it you gonna run any type of FI
LT1Falcon's Avatar
looks like its gonna be mean, what are you doing about a tranny and rear end?
Old Apr 13, 2007 | 09:20 PM
Mattybz28's Avatar
This what you took the loan out for?
What is this combo going into? Looks nice.
Old Apr 13, 2007 | 09:23 PM
the_merv's Avatar
This build is an all-motor, no bottle build, I want 10's on just Engine. My light car should get it.. if not it will be close..
The rear will eventually be a Moser 9" with either 3.90's or 4.10's, and the Tranny will be a fully built 4L60E with a Yank SS 3600. The Cam is a Texas Speed and Performance 237/242, .603/.609, 112LSA.
It will be nasty, they flow 325/210 at .600 lift with a 4.000 bore.
Old Apr 13, 2007 | 09:25 PM
the_merv's Avatar
This is goin into my Camaro, I like the look of it, and it will be one hell of a sleeper.
I'm sorry but that Engine and the combination that I am building to go into it will have more potential and power than I can get out of an LT1 at this time..
Old Apr 13, 2007 | 09:27 PM
LT1Falcon's Avatar
The rear will eventually be a Moser 9" with either 3.90's or 4.10's, and the Tranny will be a fully built 4L60E with a Yank SS 3200. The Cam is a Texas Speed and Performance 237/242, .603/.609, 112LSA.
haha nice, its gonna be killer. i was just makin sure you were doin somethin about the rest of the drivetrain, because all that power would be pointless otherwise, but im sure you got it covered.
Old Apr 13, 2007 | 09:28 PM
Why only a 3200 stall.
Formula350's Avatar
So what are you calling it? LS3, LS5? LS2.5?
Old Apr 13, 2007 | 09:49 PM
the_merv's Avatar
It's actually, by the parts, it's a LS6.6l. It's a hair below the LS7 as far as the Dimensions, and the Heads are the same, just a hair smaller Valves, and they are not factory ported.
I don't have a good name for it, unless someone can come up with something..
The SS 3200 Stall was chosen to keep it street friendly, to cream people on the Highway, and it's got a low STR, so it doesn't kill the Rear and Tranny in the car. It will still move in that light car..
I got a good deal on a Yank SS3600, so I am goin with that.
Old Apr 14, 2007 | 01:29 AM
Formula350's Avatar
How'd you make it a 6.6L? Stroker crank? And I'd say bore it out and get that LS7 dimensions, and the valves and just call it an LS7 clone Or LS7c perhaps?
Whatever it's called, hopefully you make some tire melting torque
Old Apr 14, 2007 | 01:54 AM
ridethesmallbus1's Avatar
its wierd how i get pumped on other peoples cars
Old Apr 14, 2007 | 09:53 AM
the_merv's Avatar
With that Block, the most I could safely go before sleeving it is .060 over. It's fine where it is, and those Heads are stout from the Factory. A friend of mine has a built LS1 with stage 3 Ported Heads, mine out-flow his.
What makes it that displacement is the factory 4.000 Bore and a 4.000 Stroker Crank, which drops right in without clearancing anything. It's a very easily built setup, and it's starting to get quite common. Those Heads that I have are only for a bore that is 4.000 or larger, the Valves are that big to where if the Bore was smaller, they would hit the Cylinder Walls. A regular LS1 can't use these. That is why all the Truck 6.0l Iron Blocks(Bare Block above) are a little high in value..
All my friends are hyped about it cause they don't have the money to do it, and their wives wont let them. I got all kinds of project funding, and no girl, so that thing will get all kinds of good attention..
Old Apr 14, 2007 | 12:32 PM
1bdbrd's Avatar
after reading this thread last night you have me considering doing a similar build for my 94 later this year. i started collecting parts last year for an ls1 swap and was thinking that if i picked up a complete LQ4 or LQ9 engine it should have really everything i need to put it in right? i know i would need to switch things like the oil pan and the accessory brackets but i shouldnt have to source a whole lot of small parts i wouldnt think? i was thinking that i could sell my lt1 and t56 for enough to offset the price of the rods, pistons and top end and build a nasty 370 iron block setup and still have enough to buy a t56 and the ls1 headers and such. with the sales of parts and such im thinking i could come out and spend about the same in the end as building a 355 LT1 with an LE top end..
please tell me im not dreaming about the financial end of it...
Old Apr 14, 2007 | 01:07 PM
the_merv's Avatar
Why go with a 370 Iron Block, a 402 costs the same..355 LT1 would be cheaper.
I can build a Harness for the swap, I built mine and another one is in a running car, so I know it works. Mine just has a few more custom things on it. The Accessories bolt right up to the Block, one of the bolts for the Alternator Bracket has to be drilled and tapped.
A friend of mine swapped his LS1 out for a 6.0l LQ9, and he said that it was a totally different car, and that was with stock internals. The 6.0l Engines are really strong.
Old Apr 14, 2007 | 02:27 PM
Colin91Z's Avatar
If you are building this for all motor, why the -12cc pistons? I would think you would want the flat-tops for more compression...
Old Apr 14, 2007 | 02:28 PM
1bdbrd's Avatar
how is the price the same between a 370 and a 402? i figured the 402 would be more because it uses a new crank whereas the 370 was stock crank and a .030 over bore.
Old Apr 14, 2007 | 04:15 PM
the_merv's Avatar
Most places carry -12cc as the lowest Piston, I will always run Pistons with Valve Reliefs, just incase.
I thought you would go with a Forged Setup..
In that case the 370 would be cheaper. With my Intake/Heads/Cam setup I am using, a 402 would suit it better. That, and I believe in go big or go home..
Old Apr 14, 2007 | 05:10 PM
Schweet97Z's Avatar
Merv goodluck with the setup! Keep us updated. Its def. going to be a monster
Old Apr 14, 2007 | 05:32 PM
the_merv's Avatar
I can see it now...
"How the hell is that LT1 car moving like that..."
And then watch them drool over what is under the hood when I smoke em..alot of raw Chevy power.
