why is my car so slow??
Old Apr 17, 2007 | 09:59 PM
Burning Rubber's Avatar
Default why is my car so slow??
I have a 91 RS camaro with a 96 LT1 and i got destroyed by a mustang that runs low 13s. My car has a CC306 cam/stock heads/30# injectors/underdrive pullies/slp shorty headers and y pipe/high flow cat/single 3 inch flowmaster/3.70 gears/electric water pump/manual steering/AC delete/smog and EGR delete/mail order tune.
Old Apr 17, 2007 | 10:13 PM
snk-huntr's Avatar
did you ask what mods the stang had ?
Old Apr 17, 2007 | 10:14 PM
sdm1234's Avatar
have you dyno'd your car?
Old Apr 17, 2007 | 10:23 PM
snk-huntr's Avatar
also is your car a4 or m6 and get some lts ditch the slowmaster and i got nothing on the dyno from the undercharge pullies.
Old Apr 17, 2007 | 10:55 PM
Boodyrider's Avatar
LOL, he said "undercharge pullies"
Old Apr 18, 2007 | 12:16 AM
transam5.7lt1's Avatar
That is really strange.... I would've guess by the times the mudstain runs that it should've been a close race or a victory on your favor.
Old Apr 18, 2007 | 12:20 AM
Revelation Z28's Avatar
shorties and a mild/big cam like that is kinda restricting. you deleted all your emissions but kept shorties?
you should've murdered him.
slipping clutch? any missing?
Old Apr 18, 2007 | 02:19 AM
koolaid_kid's Avatar
It should have been fairly close. The LT1 with all those deletes should have provided decent power. Low 13s are not that easy to reach, but should have been achievable, given decent traction and driving skills.
I wonder if the tune is an issue?
Old Apr 18, 2007 | 04:54 AM
i think that the tune is a major issue. the car runs rich and needs a converter bad. I cant put long tubes on there bc they come out right at the transmission and there is nowhere to run the pipes. It has a built 700r4. i would have figured that i could have smoked the mustang. the mustang has heads cam and intake and got beat by my friends sti that ran 12.8@105.9. Oh yea and my car wont burnout. It doesnt spin tires at all and has futuras on it. I have not had time for a dyno tune yet. I just got it running. It doesnt misfire at all.
Old Apr 18, 2007 | 06:01 AM
dhdenney's Avatar
What kinda LT's? A set for a 3rd gen or 4th gen? If you get the 3rd gen headers, should come out ok on clearence.
Old Apr 18, 2007 | 07:00 AM
smnitFB's Avatar
most of the thirdgen LT's work just fine, you either have to make a y-pipe or do a custom X or H pipe setup. Should work with a 700r4, I know when I had my old engine in they wouldn't work because the collector ended up right where the fork came out the side of the T5 bellhousing. Lots of autos running them though. Sounds like you need to do some datalogging and send a copy of your log back to your mail order tune company and have them do some reprogramming.
Old Apr 18, 2007 | 09:21 AM
TravisMcGill2000's Avatar
if your car ant do a burnout then something is slipping then probly tranny.might want to check it out. i have a 94 trans am a4 with a 3.73 gear and it will burn the tires slap off.
Old Apr 18, 2007 | 09:30 AM
fergymoto's Avatar
Do you still have a stock converter in there? That would kill any medium-large cam.
Old Apr 18, 2007 | 02:17 PM
I had hedman long tubes for a third gen and the collectors came out about three inches in front of the sides of the tranny pan. and it does still have the stock converter. the transmission is not slipping. It will burnout if i powerbrake it but it acts funny the RPMs are all over the place. Up then back down, then back up, then back down. It also has a low rpm hesitation. I think it may just need a tune and a converter. how big of a converter will i need. I have a cc306.
Old Apr 18, 2007 | 02:47 PM
Javier97Z28's Avatar
Is this a bad joke?
cc306? Toss a 3600+ converter in that thing.
Old Apr 18, 2007 | 04:03 PM
alrighty then
Old Apr 18, 2007 | 05:55 PM
dhdenney's Avatar
3200-3400 probably wouldn't be bad either. I would find a way to do LT's. Have you tried Hooker?
Old Apr 18, 2007 | 08:09 PM
KyleDallas's Avatar
Originally Posted by Javier97Z28
Is this a bad joke?
My thoughts also... 13's not easy to reach??? Strange comment..
There's been no mention of what year/type of Mustang you raced..
A 1990 Coupe LX is a VERY light car...some careful (stealth) weight
reduction and he's under 3000 lbs... hiding a stroker crank and gears-easy
and not expensive.
My El Cheapo E.T. calculator is telling me 3100lbs and 350 flywheel
horsepower gives him a 12 second ET potential... do you know this
driver/car?? a 347 and gears with weight management could do this
in a lightweight LX.
Old Apr 18, 2007 | 09:18 PM
the kid that has the mustang is my friend mike. The car has and edelbrock heads and intake package and a F 303 cam. stock bottom end. It is a 93 gt and he got beat by my friends sti that ran 12.86 with a 1.70 60'. So i am pretty sure the car runs low 13s. I have looked at hookers but they were so much more expensive and i couldnt afford them.
Old Apr 18, 2007 | 09:57 PM
97blkz's Avatar
I hardly ever hit 13's myself.
