cam? or not?
You can cam it if you like but springs and rockers are REQUIRED at the time of install. I also suggest you do better research on this than you did on the chain.
Where are you getting that info
. Even timing belts for the engines that use them are usually speced for a 60-100K interval. I have never heard of a specified interval for a chain in any vehicle though there may be some out there.
Closest info I can find in my two LT1 vehicle owners manuals I have right at this desk to what you are saying is "60K mile inspect accessory drive belt", you do know the cam is not an accessory right?
Maybe some service writter took advantage of you or something?
You are the ONLY person I have ever seen claim that GM put a interval on the timing chain, seen others say they thought it a good idea to change and such but nobody else has claimed what you have.
You are wrong, I don't care about some AC Delco book, they are nothing but a parts company.
I was looking for more info and found that GM's new 100K mile warranty covers timing chains, and covers timing belts up till the first scheduled maintenance interval. That means that if there was a recommended interval for the timing chain it would be over 100K otherwise like the belt it would only be covered till the first scheduled change. What would they know though they only built the cars and have to worry about their wallet on the warranty work.
