Fuel line mod write up (stock lines)
#64
The Bracket I got from a member on here, he was selling them more for a street rod application. The bracket is a dead ringer for teh madman bracket.
The power steering pump bracket I made myself out of 1/4" thick plate steel, a 4" x 10" piece and fabricated it how I needed it. The pump it's self is for a 92 4cyl grand am, the pulley for a Rivera for the correct offset, the HP line for a 4.3 full size c1500 95-99.
#72
what size tires did you have? okay about the alternator. it would be nice if there was some type of power inverter you could use in place of the alternator and have a pulley connected to the ac delete pully bracket somehow. i hate the alternator being up top..
#74
Yes i know me tooooooo. i painted mine the color of the engine bay. but the paint tends to chip off?? wonder if i sanded it down and put some primer on it and painted it then if it would stay on..
#80
So you capped off the evap hardline and left it like that? you didn't do anything with the actual canister. i ask because i just did this mod myself but using braided lines. i capped off the hardline too but was just wondering about the canister. could it fill up with gas or fumes?
