Moroso Cold Air Intake
Old Apr 25, 2007 | 08:29 AM
95TAGary's Avatar
Default Moroso Cold Air Intake
Does anyone have the Moroso cold air intake on their LT1 with a vortech or trick flow elbow? I'm trying to install mine and to get everything hooked up with the MAF sensor looks like I have to cut about 1-2" off the end of the Moroso to get everything installed? Has anybody done this as well?
I hope its normal.
Old Apr 25, 2007 | 09:34 AM
TwoFast4Lv's Avatar
Did you wind up with on for a 93?
Old Apr 25, 2007 | 10:15 AM
KTM's Avatar
KTM
I have the moroso CAI and the elbow that looks like the factory one - but doesn't have the donky dong on the bottom...it all fits like a glove - no issues.
Old Apr 25, 2007 | 10:29 AM
95TAGary's Avatar
I ordered it from the WS6 and they knew I had a 1995. Didn't know they made two sizes? I'll check but its to late I already took about 1.5" off the end to get everything hooked up right.
Just checked and I ordered the 94-97 Moroso kit. I must be doing something wrong unless my Vortech elbow is alittle longer than stock? I'll try again after work.
Old Jan 8, 2009 | 01:44 PM
joeZ96's Avatar
I had to cut about 1.5 inches off of mine as well years ago with the stock elbow.
Old Jan 8, 2009 | 02:44 PM
1badzee's Avatar
Do what you have to do to make it work. It's not a big deal
Old Jan 8, 2009 | 02:47 PM
SprayedLT1's Avatar
Yes, I had to trim mine when I put a Trick Flow elbow on. With the stock elbow mine fit fine, so I had the correct one for 94+
Old Jan 8, 2009 | 05:15 PM
93lt1M6z's Avatar
i had a trick flow and had to cut it...no big deal
Old Jan 8, 2009 | 05:47 PM
tspence45's Avatar
When I had my Moroso cai and CRT elbow, it fit just fine.
Old Jan 8, 2009 | 07:26 PM
irocchenault's Avatar
i have the moroso on my 96 z28 and i had to cut about an inch off of mine. after the cut everything fit just fine.
Old Jan 8, 2009 | 07:49 PM
96formulabird's Avatar
I have the same set up u have. i had the exact same problem. all i did was turn the mass air flow sensor so the connector is on the side and plugged it up and now the hood closes with out a little bulge sticking into it. just turn it to the side and it works fine. never looked back since installing it.
