Help! Gained 9tenths and lost 6MPH! Any help please.
IMO the Dana 60 is just silliness that is the rear all the guys with big mud and rock crawling trucks want. absolutely foolish to put one in a car like this and here you can see the results. I do think weather is a part but that axle is just too big.
The b-bodies have VERY few problems with the 8.5" 10 bolt despite all our extra weight, our 30 spline unit is comparable to the 12 bolts of old. For a street f-body that needs an axle upgrade I think the 12 bolt a good choice because I know it is available the 30 spline 10 bolt 8.5 would do if someone built it. On a race car an 9" will do the trick. Leave the Dana 60 to the off roaders.
This is the same "more is better" mentality so many of you apply to the cams and it is working just as "well".
I once lent a TH-350 to an LS1 buddy of mine. He swapped out his race prepped TH-350 for mine and gained over a tenth (and it wasn't even my best TH-350).
The steel driveshaft is also a great way to rob power.
