port pros vs. lloyd elliot
#41
Perfect, just asking so those that might believe or not believe this will actually know. and they can confirm this as well with a call.
No harm intended.
No harm intended.
Originally Posted by Speed Density
Um....
Because I emaild Ron last year and asked him about it.
Thats why.
Tony.
Thats why.
Tony.
#43
Do they just use this in place of the clay that other companies use to smooth the port entry??
There are so many variables that go with flowing heads it really is silly to shop flow numbers IMO.
Ai doesn't use a pipe, AFR does ect ect, there is just too many different ways to do it.
#47
LS1TECH Sponsor
You can't go wrong with Port Pros, Elliotts Portworks or the other non sponsor mentioned. If you have attention to detail on the rest of the set up (CAI, TB size, ported intake, big headers, good exhaust and GOOD tuning), you will see good results from any of them.
If it all goes in a car with a good 60 ft, you will get good track times and if the car has some weight reduction, it will be even faster.
There are ALOT of ways to lose HP and end up with a slow car and the difference in any of the heads mentioned will NOT be the deciding factor.
Call each of them and see what parts are used at what price and how quick the turnaround time is and then decide who you are most comfortable with.
#48
hashtagBMW
After going over the email from Ai about using 'wood' on the flowbench, I realized it was not wood and was 'clay' instead.
Its most likely the same process of molding to the clay to the intake runner, as stated before with the wood.
And Lloyd,
Nice of you to Join us as a Sponsor on LS1Tech![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Tony.
And Lloyd,
Tony.
#49
Really you will be happy with any one you choose. I have yet to hear a bad story from any of these guys.
#50
Originally Posted by Shon Herron
the one that produces the results that you are looking for.
is it dyno numbers?
is it track numbers?
is it dyno numbers?
#52
Originally Posted by 97Lt1TA
looking at more at track times. im sure port pro and le heads will give me over 400 hp which i am looking to make but im mostly focused on track time. would like to see low or mid 11s all motor
track times def are somthing people should focus on rather than power..
Look at how fast 5.0 guys can run, and they barly make over 300whp
#53
#54
See my LE #'s in the sig. I still have quite a bit of room for improvement too.
MPH through a 4000 stall and a Ford 9".
#55
Originally Posted by Javier97Z28
Track numbers talk.
would like to get my old *** 190 AFR ported .
#57
Originally Posted by LT1MAN
all the head porters grind cams to match the heads.
#58
Just my .02 but I believe that the reason why I am putting down such good numbers is due to my Port Pros Heads. Cause its probably not from my baby hotcam lol. I always support port pros, great guys and great work.
#59
[QUOTE=NightTrain66]You can't go wrong with Port Pros, Elliotts Portworks or the other non sponsor mentioned. QUOTE]
Lol. That "other non sponsor" was YOU for so long. Now you wont even mention their name. Irony.
But I agree with everyone else, all good porters. Variances, but all good.
#60
[QUOTE=Tireburnin]
![Violen](https://ls1tech.com/forums/images/smilies2/violen.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
