head gaskets?
Old May 3, 2007 | 10:37 AM
plaf713's Avatar
Default head gaskets?
i have a 383 so wouold that make the head gasket a 4.030 bore size? if so why can i not find any gaskets that size in jegs or summtracing? thanks for the help
Old May 3, 2007 | 10:50 AM
Javier97Z28's Avatar
Most head gaskets accommodate from a stock 4.00" bore all the way up to a 4.125" bore.
Off the shelf gaskets are not made to a specific bore size.
Old May 3, 2007 | 11:15 AM
396D1SS's Avatar
Old May 3, 2007 | 11:30 AM
plaf713's Avatar
any suggestions for a 383 gasket?
Old May 3, 2007 | 11:35 AM
Depends on your target quench and compression ratio.
Old May 3, 2007 | 11:46 AM
plaf713's Avatar
im running trick flow heads and i dont want my compression to drop to much so i might get a thinner gasket, but i am on a budget so i dont want to get new pushrods. i really have no clue when it comes to head gaskets
Old May 3, 2007 | 11:58 AM
You're running trickflow heads with no milling? *sigh*
Stock pushrods? *second sigh*
You may want to wait to finish this thing until you have the $$ to do it right. But in any case, you shouldn't determine pushrod length until you actually checked it with an adjustable pushrod anyways.
Building engines isn't a guessing game.
Old May 3, 2007 | 01:12 PM
plaf713's Avatar
makes sense, thanks for the input
