possible full bolt on to run mid 12's?
Old May 3, 2007 | 06:17 PM
Lt1CamaroSS's Avatar
Default possible full bolt on to run mid 12's?
i ran 13.4 with free mods,cai and exhaust...is it possible to run mid 12's with full bolt ons including gears,converter and dr's?
Old May 3, 2007 | 06:37 PM
procamaroz28's Avatar
sure it should be easy
Old May 3, 2007 | 06:38 PM
but forget about dr they'll just end your rear
Old May 3, 2007 | 06:47 PM
Mattybz28's Avatar
False.
Old May 3, 2007 | 08:09 PM
ridethesmallbus1's Avatar
maybe.
Old May 3, 2007 | 08:13 PM
i know people running 11's with stock rears just with moser axles...how fast could a bolt on lt1 run
Old May 3, 2007 | 11:51 PM
FlashLCD33's Avatar
Believe in the LT1 time threads the fastest bolton LT1 is 11.80
Old May 3, 2007 | 11:57 PM
GreatWhiteZ28's Avatar
Mine's cuttin 13.20's With full bolt on's and Dr's out back with a Yank 3200..it's capable of a 13.0 - 12.90 with a good launch....but I'm gonna say mid 12's with just full bolt on's will require some supsension tuning and a slight Diet.....but that's just my .02
Old May 3, 2007 | 11:59 PM
FlashLCD33's Avatar
Shon Herron-11.805@113.96, 97 Z28 M6, Bolt-ons/NA/3100lbs "Bolt on Record"
There it is.
Old May 4, 2007 | 01:56 AM
Dragframe's Avatar
you must be at a shitty altitude like me
Old May 4, 2007 | 08:34 AM
burnzilla's Avatar
First off, that is a good time for the mods you have, congrats.
Secondly, it depends.
Longtubes, DR's and a stall will definitely get you into the 12's, but how deep is up to you.
Suspension and weight reduction are the big ones, besides a killer 60' foot.
If you really want a killer time, throw on a set of Mickey's and skinnies for a pass or two.
If you get all those things, I don't know If I would recommend gears on the stock 10 bolt with a stall and DR's...
its up to you though.
Old May 4, 2007 | 10:10 AM
Shon Herron's Avatar
What you want to know :-)
Old May 4, 2007 | 10:15 AM
street demon2k3's Avatar
Hit it on the money! I ran 13.03@103 with just LT's, stall, slicks/skinnies, and some free mods. I went back on street tires with full bolt-ons minus 1.6rr and ran a 13.3@106 with a crappy 2.2-.3 60ft. Prolly could have gone 12's but I didnt have my et streets that day. Consistent low 1.7 60ft's and some good weather should get you 12's no problem. But get some skinnies, pull your swaybar, might even want to remove some interior stuff as well to keep the weight down. Contact Shon or do a search and see what he does to keep down weight, and how good of a suspension he has.
Old May 4, 2007 | 10:49 AM
yea..im either gonna do a stall or gears but im hoping to go mid 12's..is the stock rear any better with axels? what bolt-on should be next that would drop my et the most?..besides dr's
Old May 4, 2007 | 11:32 AM
Im at around Sea Leval...slick *** Nittos, and didn't get out of the hole without spining..HRP is the next stop for another Run, this local track just plain blows
Old May 4, 2007 | 12:31 PM
1st thing to do: Remove as much weight as you can.
2nd: get a set of tires that are worth a cuss.
A GOOD TC will help you most of all, then gears. And if you want all out ET then pick the gear set that will get you to the 6kish RPM at 1320 feet. Most will not like it but in the A4 4.10s are nice and even more is better!
And race for ET on GOOD Weather days, where the DA is in the trip digits or negative!!
the other days are for fun.
Old May 4, 2007 | 03:06 PM
vtec's Avatar
Resident Racing Jerk
i would run the stock 10 bolt with a bolton auto. (with 4.10's)
