Dealing with LS1 people..
. lolDoesn't really matter lol I miss my TPI. I think it was much faster than it should've been for what was done (free mods and tune).
Rothman, if that's how you feel about Merv, then you know exactly what everyone here is talking about, except it's from LS1 owners.
Where did I refrence and talk **** about you..no where..so pull you EGO down a couple of notches.
I said you had a nasty setup, I gave you props on that, and you were trying to knock mine..said that you can run it and I am not goin to be that much more over you..I got almost a whole nother Liter, it's Built/Balanced compared to your stock bottom end, and it's going to pack a ****** nasty punch..I think that is a little bit more than "not much more"
I heard about how you said that you would be able to hang with that Engine I am building.. Come on, you are a 346, I am going to be a 402..with bigger and better Heads, higher Compression, bigger Cam, and a lighter car setup. And you are a M6, I got you out-shifted already. I'll stick with that A4 cause it will be stomping some *** on the Track.
I'll see your mid 11's, and raise you a low 11/sub 10 pass, and that's not even with it's full potential..
You're the first one I am looking for after it's broken in..
Besides, you come in here trying to dog me..I'm suprised. Wrong field to talk **** on though, I have alot of friends in here that I have helped and that have helped me, like mentioned above.
And yes, even after that Engine is in and running, I am still helping you all out with the LT1 stuff, I am trying to master both Engines..already got the Harnesses down. I am not going to get a big head cause I have a LSX Engine.. I'm still representin the early 4th Gen, and gladly stompin the LS1's into the ****** dirt, just for that reason^^
Be afraid Rothman.. I'm comin with a 6.6 Liter LS1 EATER..in that shitty lookin early 4th Gen
What happens when you're done w/ your LSX fbody and try to stomp a LS1 fbody and you get stomped? Remember NOT all LS1s are stock and there are always be FASTER car than yours. That being said...
I said you had a nasty setup, so again take your EGO down a couple of pegs.
As far as making friends go, if you are concerned with your car that much to where you are all "oooo he said this, my ***** hurts...oooo" There is a Isle at Wal Mart that has this **** called Vagisil on it, go check it out..
Speaking of sayin **** to my face, why you typing it on here? Grow some things called ***** and catch me somewhere..I am at the Fire Station from time to time, I think you know where that is..
I know I talk about my ****, I talk about it alot cause I am proud of it, it's custom work based on lost of research. Listen in and you might learn something, I talk with all kinds of people and learn how their stuff is setup, that helps me out, gives me different ideas.
Well I'll be sulking in that corner as I'm getting some in a little bit.. so yea..have a nice night..
There is always a faster car out there, that's a given no matter what you own.
