Does anyone have this cam?
Comp Cams XFI LT1 Camshaft, 242 / 248, .584 / .579 113 LSA, Good midrange with excellent top end power. Headers, exhaust, gears, converter, computer tuning recommended.
--Alan
Thats also what I finally learned. bigger is not necessarily always best.
The MS4 is a high Lift- meduim Duration Cam..this one is opposite. I am goin with the MS3, it's pretty much the MS4, just the Intake Lift is .603 instead of .650..
you will need to upgrade to the 1.6 rockers, as that is the rocker used for the lift stated.
if you consider 242/248 .584/.579 113 huge...what do you consider 246/254 .613/.590 112
236/242 .580/.585 111
Just a little sample of what it sounds like. Right click and "Save target as".
With Open Borla:
http://getonitracing.net/videos/Donnie2.wmv
With Open Headers:
http://getonitracing.net/videos/donnie.MPG
These are SAE corrected numbers and the correction factor was about .95-.96. I also had about 3-5* of knock retard.
Don't mind the name or the AFR. Wideband was broken.
For reference (approximately):
MPH RPM
58 3100
64 3450
71 3800
77 4100
84 4500
90 4850
96 5200
103 5600
109 5900
116 6250
122 6600
The bigger is not always better comment from above rings true too, it is an age old hotrodding mistake that people insist on repeating over and over.
With Open Borla:
With Open Headers:
MPH RPM
58 3100
64 3450
71 3800
77 4100
84 4500
90 4850
96 5200
103 5600
109 5900
116 6250
122 6600
With Open Borla:
With Open Headers:
MPH RPM
58 3100
64 3450
71 3800
77 4100
84 4500
90 4850
96 5200
103 5600
109 5900
116 6250
122 6600
