A/C Firewall Stuff, removal
I am a little confused...is the box on the firewall not connected to the box under the dash...In other words, removing the box on the firewall DOES NOT mean the piece under the dash has to be removed also?
I am trying to remove my AC and KEEP my heat. I am a little confused how this is done...
I put that flashing piece in it to divert the Air into the Heater Core..the stock one has a piece there you have to cut out of the way.
And yes..I didn't do anything with the Dash, just cut the outside off..
This is off topic, but what is the setup u have in your last pic. Some kind of temp. sensor in a coolant hose.
Yea..that is the current Temp Sensor for the Gauge..playin with places to put it and that seems to work for now.
