So they mixed my coolant....
Old 12-23-2007, 10:15 PM
  #41
jasonp31's Avatar
Mixing green with orange should not causing a "gelling" problem like I've read numerous, numerous times.
What will happen though, is the two together will lower the corrosion protection significantly. I do not recommend mixing the two unless you're in a pinch.
Old 12-23-2007, 10:51 PM
  #42
dhdenney's Avatar
Originally Posted by 1bdbrd
No it doesn't. You are 100% completely wrong and should never post that information here again. I mixed the coolant in my old car damn near 5 years ago and it still runs to this day without a single coolant related problem and never has had an issue.
The gelling theory has long stood cuz I've read it/heard it for a while myself. Is it true? Dunno. I ain't gonna try it though.
Old 12-06-2008, 02:01 PM
  #43
crookedbowtie's Avatar
Originally Posted by a90sickz
**** i have my lt1 just shitting outside in the rain with 100% water in it. that means a have to flush? or it doesnt hurt for a lil while
Darn good way to crack your block. It freezes were I live, at least put some antifreeze in with the water. Are you crazy?
Old 12-06-2008, 02:50 PM
  #44
AChotrod's Avatar
Doubt he will ever read this since its an old thread.
Didnt they release some info claiming all the dex cool BS was in fact BS and that dex cool itself causes issues?????
Old 12-06-2008, 04:14 PM
  #45
IronOutlaw's Avatar
Actually, it does cause a brown goop when they mix. My dad mixed the green and orange in my moms 98 olds mini-van. It was a big mistake, it stopped up everything and warped the heads. You could see the brown stuff collecting all in the resevoir.
Old 12-06-2008, 04:25 PM
  #46
xx_ED_xx's Avatar
The brown stuff was oil and coolant since the intake gaskets suck on those vans. And yes there was a lawsuit about it dex cool supposedly is bad. Who the hell knows. I think if it has a leak or is going to leak doesnt matter the color. I used to be a GM tech. 3.1 3.4 3.8 4.3 5.7 pretty much all of them with them stupid plastic intake gaskets leak. Or even worse plastic upper plenums that water and exhaust etc run thru. Brillant engineering feet i say
Old 12-07-2008, 02:48 PM
  #47
AChotrod's Avatar
I was reading it is not the dexcool itself but if it get scontaminated with impurities or air in the system and heats up to much it can get goopy?
Old 12-07-2008, 06:02 PM
  #48
dhdenney's Avatar
I've got an idea. Don't use Dexcool.
Old 12-07-2008, 07:17 PM
  #49
TwoFast4Lv's Avatar
Originally Posted by topgunbar0
ya if you mix the orange with the green it becomes gloopy and gelly and is a complete b**** to clean out and clogs like a ****
Actualy the new green coolant can be mixed with any thing.
There is so much coolant wives tales out there that is for sure...
Old 12-07-2008, 09:06 PM
  #50
AChotrod's Avatar
Very true Ellis! Almost everything says it can be mixed with any color coolant these days
Quick Reply: So they mixed my coolant....
