Turbo?
I'm fixing to revive my 95 Z28 from the dead, and i was thinking about doing a single turbo setup.
But I was wondering why I don't see very many done to LT1s, even on the fastest LT1s list.
Anything I should know before i start spending money and time :X
https://ls1tech.com/forums/showthrea...0&page=1&pp=20
Page 3 has some more pics. He'll probablly be posting more soon, Ive seen the new pics with the coated stuff hung on the car and with all the pipe routing done.
Theres another guy I see posting in this section from time to time. "Dragframe". He has a turbo setup I think, but I dont know the specifics. Theres also a Red LT1 Camaro ive seen in the FI section with a TT setup thats pretty unique. **edit: Intmd8 is the guy I was thinking of for the TT setup. You can find his website and stuff with all the pics**
Turbo setups are alot of work, And if you cant find a kit you need to be decent at doing fab work and welding to get it done. Even if you find a kit, you'll probablly need to do slight modifications to your setup to get it to work, its just the way these things have gone that ive seen. We're planning on doing one for my car, but still in the planning and engine buildup stages. Its alot of little things to get a turbo setup going. If you browse around the Forced Induction section of the forums you'll probablly turn up more information than you can use.
-Josh
you pretty much have to step up to a full standalone as there arent many other good options.
As mentioned above, space in the engine bay is at a premium, so anything you add in there makes access to everything more difficult.
The downside to a rear mount is the length of the intake tubing and the oil lines to the turbo.
Any turbo requires major tuning once implemented, plus all the extra items, such as larger injectors, gauges, etc.
turbo, using a scavenge pump for the oil drainback since it was mounted rather low, taking the place where the driver side cat was located, then routed the intake plumbing to a horizontal mounted ic that i made from 2
supra cores, feeding into a k&n plenum intake and 1le elbow. i used
30 lb. svo injectors and a 12:1 fmu at about 8 psi. car ran really strong.
i would have to say as strong or stronger than the 383 with ported lt4 heads
and intake combo i had, although the 383 had th400 and athe turbo was
a t56. but the 383 car was a mid 10's on 175 tb plate shot.
wideband o2's were not as available at the time. but the car stayed together
for over 2 yrs., until the guy i sold it wrecked it.
bottom end was rebuilt with sbc forged pistons and rings, on stock rods and crank, clevite bearings, stock heads and intake.
single plane intake with elbow plenum along with some hi flow sbc heads and a edis 8 for ignition. might as well go better everything.
just alot more options for heads and intakes for the sbc
motors, the late model vortec truck engines are also rollers,
and it would bolt in place of a lt1, also it is alot easier to find the 4bolt main
vortec truck engines, just throwing some ideas out there
Hopefully soon I will get it done soon and get some vids up
