383 vs. 396
i believe the only difference is that the bore is larger and the storke is a lil bit longer...same idea as a 383...just bored and stroked a little more...correct me if im wrong.
I know there's no replacement for displacement, but the right built 383 can put the right Fbody in the 9" and produce 500+. I've seen MANY 450+ RWHP 383's. I dont know hom much more a 396 cost to build but i'm sure if you wanna go that fast, money is no object
www.fast93z.com Tony Shepherds 396 is absolutely wicked! Theres quite a few guys on here pushing 500 plus to the tires on both 383 and 396 setups. I plan on being at 500 plus with my 383 in the next couple weeks. That is very hard to achieve with an LT1 unless you go solid roller with a hugely upgraded intake such as a converted single plane.
Originally Posted by Paul Bell
Ed Wright Makes 532rwhp through a 4L60E and 12 bolt with a 30+" tire. Ported Lt4 intake....
With what size engine?
383cu in. Worked Lt4 castings and LT4 intake.
