piston compression height
Old May 28, 2007 | 06:57 PM
Ari G's Avatar
Default piston compression height
what is the LT1 piston compression height?
Old May 28, 2007 | 07:42 PM
siniSSter's Avatar
stock height =1.568
Old May 28, 2007 | 07:55 PM
Ari G's Avatar
thank you,i had a hard time finding it
Old May 28, 2007 | 07:59 PM
siniSSter's Avatar
No problem, here is the formula in case anyone else needs it, or searches it in the future.
9.025 - block height
1.740 - 3.480 divided by 2
5.7 - rod length
0.17 - deck clearance
9.025 - 1.740 - 5.700 - .017 = Compression Height of 1.568.
Old May 29, 2007 | 02:06 AM
94z28L's Avatar
5.7 - rod length
good post
Old May 29, 2007 | 03:30 AM
Karl Ellwein's Avatar
That is the formula to calculate a desired compression height.
The actual stock Mahle LT1 piston part number 027520 has a compression height of 1.559"
That gives you .026" in the hole.
That is:
9.025 - (5.70 - 1.559 - 1.740) = .026"
But an aftermarket 5.7" rod 3.48" stroke SBC piston usually comes with a 1.560" compression height, (for zero deck height on a 9.000" decked block).
Karl
