lt's vs. mid's on a daily driver, what do you think?
Originally Posted by wrd1972
The stock exhuast bolts up nice with the Mac's. Install is clean.
I still think the RK sports and AS&M's are better headers since they will work better down the road if you modify the motor, but they are a SOB to install and plug access is horrible.
Borla: pretty respected name in the exhaust market right? Well back when the LT1 was still in its heyday, they actually made headers for it. And guess what type've header they chose to produce? 304....stainless....MIDLENGTHS .
(Excuse the header on the right, I'm still in the process of polishing them.):
Since they were the only stainless headers available for LT1's at the time, they were pretty expensive. Borla stopped making them after demand went down when other companies like Edelbrock and BBK started making cheap painted/ceramic midlengths.
They very easily could have made longtubes, but the fact that they chose this particular design instead, says something.
look easy to install too
From David Vizard:
yes, but when youre launching the car at 3000-4000 rpm, i dont think you need to worry about any bottom end torque being lost! and besides that, its not a dramatic loss in power. ive got 300+ftlbs of torque starting at 1500rpm so Longtubes for the win!
You launch at 3,000 rpm's, but not everyone else does. In your particular situation, longtubes happen to work better: however, this doesn't in any way disprove the benefits of midlengths. Simply applying the "bigger is better" philosophy to all situations is a mistake, because the fact of the matter is that the owner's needs/goals are ultimately what determine what parts are going to be necessary, and the performance characteristics of longtubes are not always going to match up with them all.
I will agree that overall for most people the LT's are the best, but all options should be considered except shortie headers, they suck.
Originally Posted by RedLT4Mike
yeah. the y-pipe bolts right up.
I ran it that way for a week back in the day.
Shorties can work quite well, it is the knowledge level of the average poster here that sucks.
I am not claiming shories will be completely equal to mids or longtubes but they are a HUGE step up from manifolds. Lot of b-bodies out there running very well with SLP shorties.
Anything is a large step up from stock manifolds. For an F-car, I don't see a real reason to look at shorty headers when there are great mids out there. That may be different for a B-body, but less than 1% of guys on here drive those.
But back on topic, I'm installing my coated Pacesetters and TDs on my DD very soon. I wouldn't spend money on headers and not get a long tube. But that's just me.
#32
I run midlength headers because they were available with hookup pipes to a stock style catback(LT1 b-bodies got duals) works just fine even the 1 5/8" primaries are just fine.
Go back up and read the Vizard quote, that man knows his smallblock Chevys.
#33
I can't complain about the Mid Length headers. I have them and the car sounds great, better than my buddys LT (but his motor is stock). Is fast as hell. Launching at over 2500 or so will light up the tires.
It is my DD and driveways/speedbumps were a concern.
on a 97 Mids will force you to relocate the Cats (if you still have them) and get extentions for the rear O2's (or sims/lt1 edit delete if no cats) Also you will not have to lift the engine to get mids installed (LT you will, I hear) I did remove a valve cover for the 1/2" I needed to get it in. No steering linkage removed to install them.
Do the plugs at the time of install they are a bear to get at some of them afterwards.
#34
Originally Posted by Ironxcross
well that sounds pretty good. i was starting to cringe at the idea of changing the whole exhaust just for headers.
#35
Moderator
They could have BUT, back then you gotta remember not many people were doing long tubes on these cars. Back mid 90s, most people modding these cars were using shorty and mid style headers. I remember the edelbrocks and macs being really popular, the faster guys were using the AS&Ms. Didnt really see to many using LTs.
#36
Originally Posted by SuperDave383
but why would you wanna get lt's and keep the rest of the stock exhaust? kinda defeats the purpose. if your gonna get headers, just go ahead and get a full system.
#38
You might've said it earlier in the post, but I sure hope you're planning a cutout or something then. If you have the stock catback as your only means of flow, don't even spend your money on headers.
#39
Shirley Temple Drinker
I have BBK shorties, which honestly are just as long as most the mid length headers on the market that I've seen, and I love em. I get a power increase over stock manifolds, I get the ease of plug change ( if you can call it an ease lol ) and I don't deal with low slung LT's that drag ( roads are horrible around here ) but The headers were on the car when i got it, and if I had the choice to make, I would have sacrificed the drive-ability risks for LT's, but thats just me... ( one might say Im a bit hard core? lol ~!~PeAcE~!~ )
If money was no concern;
Kook Lt headers
True duals over the axle, all custom and perfect, with some pretty quiet mufflers
( when I say quiet remember that I drive my car 24/7 365 days with the cut out open lol, just would want something a bit easier to talk over )
and of course Dual Electric cut outs off the headers for the pimp factor lol
Kook Lt headers
