changing plugs..
Old Jun 5, 2007 | 09:37 AM
Lt1CamaroSS's Avatar
Default changing plugs..
im spraying my car soon and i have to put new plugs in...i have stock exhaust manifolds...is it as simple as just pulling the put and using a regular socket? or are there any special tools or tricks ill need?..its a 94 lt1
Old Jun 5, 2007 | 10:32 AM
Rowdy94's Avatar
Eh, just use a regular socket. I didn't need to pull the alternator or starter either, although pulling the alt would make it easier. Didn't see the point of removing the starter, since it has nowhere to go with the y-pipe there.
Old Jun 5, 2007 | 12:09 PM
SlowGreenTA's Avatar
dropping the starter down helped me by allowing a bit better reach to the back 2 passenger side plugs. When we were doing them on stock manifolds it was always a chore, we'd just remove the intake stuff, alternator, and lower the starter to try and make things easier.
We also used to use a spark plug socket with one side cut out of it, But I did them once without that as well. Its tricky for sure.
-Josh
Old Jun 5, 2007 | 01:00 PM
Revelation Z28's Avatar
the 5/8 socket with a wrench fitting is the best. use a 3/4 wrench on it in tight areas where a ratchet wont fit or will hardly fit.
Old Jun 5, 2007 | 01:38 PM
Rowdy94's Avatar
Yep. Revelation brings up a good point. The wrench will be the only thing to get the rear pass. side plug out with stock manifolds.
I'm an idiot. I just did it, when I could have waited less than a month to do them when I put my LTs on...But nooooo, I had the box sitting there so I just had to go and do it. I have a sickness. lol
Old Jun 5, 2007 | 01:54 PM
Razor_Blade's Avatar
LOL...I did the exact same thing.
Old Jun 5, 2007 | 09:48 PM
the_merv's Avatar
I have no AC and the Fire Wall Panel Mod.. so that definately helps. I use the Plug Socket and a 3/4 Wrench, took me 35 min with LT's.
Old Jun 5, 2007 | 10:40 PM
yea..im just lazy to do it because i hate stupid things that take forever to do lol
