Change head bolts for head studs?
I may not have to do it, but if the boost is lifting the heads (it may be, doing the checks now) I will need to do something.
BTW, the engine has only 1000miles and 4 passes down the 1320.
Thanks in advance!
We're getting a high rpm miss and have just about eliminated everything else as a problem. Opening the opti up when I get home to see if anything came apart inside. After that check, we have one theory with the fuel system to check. If its not one of those two, the only thing left is the heads lifting when teh boost gets up to 13+ psi. The heads have been retorqued already (about 4 bolts per head were slightly shy of spec).
When I get it all back together were gonna do some more testing. So by the end of the week we'll either have it sorted out or be ordering a set of studs to clamp her down better.
Ive been going to the track with a local N20 guy that suggested lifting the heads could cause the exact issue Im having. He's got a deep 8sec S-10 with a 410ci SBC making upwards of 1200 flywheel hp. When he gets too much cylinder pressure and lifts a head, he gets a high rpm miss from water entering the cylinder. Then it runs fine off the juice and checks out fine for compression upon testing.
Shouldnt be to hard of a swap if your taking the bolts off anyway.
Tony.
If you are lifting the heads you should see some water down the side of the block.
Give me a call and we can go over this before you decide to make the change.
Harold
512-257-0222
Harold, I will give you a call on this. Just trying to eliminate all other possible problems first. Id rather not do this if I dont have to.
On a side note, since we've been having issues with the converter... Im gonna wait on that custom grind cam for a good while. And just try to get the most out of the current setup first. When the time comes, I'll have you get the cam and intake going for me at the same time.
For now, its down to finding time to work on it and sort the bugs out. As well as install the Accel DFI setup.
Yea I think most people would know that. The stuff I recenty used cures in 3 hours.
Tony can't keep a tranny in that thing..... How do I know? Cause his tranny guy has been "convinced" by a few alexander hamilton's to put crappy parts into his 400 until my engine is in the car....
If you only knew how much I have paid your engine builder to forget a few torque specs you would be skeerd!
