compression Estimate
Old Jun 13, 2007 | 01:13 AM
95FbFormula's Avatar
Default compression Estimate
Can anyone give me a compression estimate for a 355 with -5cc flattop pistons, zero decked block. 56cc combustion chambers on the heads and a .029 thick gasket.
Old Jun 13, 2007 | 06:35 AM
1redta's Avatar
Default re
input all that info into kb silvolites compression calculator....or you could probaly search that since it is a common setup Took me 5 seconds 11.816
Old Jun 13, 2007 | 09:15 AM
PortPros1's Avatar
I have 11.73 to 1, if you truly have a zero deck with a .029 head gasket your pistons will hit the heads at high rpm, you need a minimum of .038 clearance between the pistons and the heads.
That .038 number is using good bottom end parts.
Harold
Old Jun 13, 2007 | 09:21 AM
dhdenney's Avatar
http://www.torinocobra.com/Randys_tools.htm
Old Jun 13, 2007 | 12:03 PM
Harold
Thx for the advice that would have been a costly mistake i wouldn't have known. a .038 would be the fel-pros i assume but i might just go with stock lt1 thickness to be on the safe side then. Thx for the compression inputs everyone i was between getting a set of ported trick flows and milling them to 56cc chambers but i might just use the stock castings
Old Jun 13, 2007 | 12:10 PM
I guess another question would be is should I leave the deck height of my block stock with my set-up in my sig or with a zero decked block spinning the motor to 7k what size of head gasket should i go with. assuming the heads have been milled.
Old Jun 13, 2007 | 12:20 PM
Ken95Z28's Avatar
Mine has been zero decked and running the FelPros and have no issues at all.
Old Jun 13, 2007 | 01:04 PM
siniSSter's Avatar
+1---Zero Deck must use a 0.39 gasket....
