where to get parts for roll up windows????
anyone know a good place to get parts to go from electric windows to hand crank roll up??? or have any to sell it is for a 93 Camaro Lt1....Thanks
I found mine from someone on this site. You have to look around alot and find someone parting out a car that had them. Or you can go to the dealer and buy it all new, but that is expensive. I got everything I needed for under $60 bucks. That included all the window tracks, regulators, handles, and all the hardware needed. All I had to buy new was the plastic bushings for the glass.
Thanks for the info just curious on what parts i may need???? since u have done this conversion can u give me a breakdown... did u just drill a hole for the crank? Thanks
I currently do not have door panels. I am fabbing up some sheet metal door panels and I'm going to cover them in the same black tweed as my drag seats.
If your window tracks are good, all you need is the manual regulator and handles. And maybe some misc hardware and plastic window bushings if you break them.
I know the factory door panels I had could not be used with manual window, the speaker stuck out to far, and the crank handle would hit it. I think they made special door panels for the manual windows, or possibly different on the camero. It may be a stereo option as well, with bigger speakers up front. Here is a picture of a door panel with manual windows and door locks.
I don't know if they are interchangable, but on my 3rd gen Camaro, i'm doing the oposite and retrofitting electric windows, so I will have all the manual stuff left over. I've got the drivers side done, just gotta get off my a** and finish the passenger side now.
If someone can varify 3rd and 4th gen are the same, you're welcome to what I will have left over after the swap.
Sara Lou
Sara Lou
Originally Posted by 1SLO6
so what do i need to convert??? i have no clue......
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
The holes were already drilled in my car. All I had to do was replace the electric motor/regulator with a manual regulator. Then put the handle on the manual regualtor.
