Can someone read these plugs for me?
Touch lean - particularly since they are '42' plugs. That is the coldest plug A/C makes. If you are running that plug lean you can add some more fuel.
Personally I wouldn't throw them away though...you haven't hurt them a bit in my opinion.
Originally Posted by dhdenney
Someone go into a little more depth on those pics. I have always wanted some deep explanation on plug reading. I just know a black plug is running rich.
That should help some.
Originally Posted by Ralls
http://www.centuryperformance.com/spark2.asp
one thing I noticed is there is no antiseize on them, I use it everytime I put plugs in any car, just rember a dab will do ya. and they appear lean with some carbon on the inner wall of the metal, below the electrode.
So here's the thing, I really can't control the fuelling except for periods when it's running open loop (cold start and high load). These plugs were pulled after some time of normal driving without any high load operation. So other than trimming fuel a bit for cold start there's nothing that I know of that I can do for closed loop operation in terms of fueling. It's running off the O2s right?
I am going to try an even colder plug, an NGK BR7EF, 2 heat ranges colder than stock, which is probably what the motor should have (it makes 500hp). I can't tell what the R42's cross reference to. The only info that I got was from Autolite who said it crossed over to their 103 (one heat range colder than stock)
Overall it does look like it's running hot if I had to guess, but is this from fuel mixture being lean or is it from timing being retarded/advanced?
I remember reading somewhere that anti seize on the threads could do some harm. Can't remember why though, so I stopped using it. I usually don't leave the plugs in for long anyways so I don't think it's an issue for me.
Funny thing is, the valve cover doesn't leak. That plug was a bit loose. Can't get it tightened down right with the tools I have, the spark plug socket won't fit over it because of the header tube is in the way. It's probably some combustion chamber junk that's blown out from around the threads. I specifically checked for an oil leak above that plug and it's bone dry.
Originally Posted by indirocz28
they look a bit lean, also you have a valve cover leak..- imagine that..
You may be a little lean not much though, But you have way too much timing. Your A/F ratio may be right but the timing could cause your plugs to look a little lean because your combustion tempratures are higher(wich is cleaning the plugs off better). So going to a colder plug probably is not the answer. If it was me I would back off the timing a bit and see if your plugs change at all.
Originally Posted by 7zark7
Can someone explain how too much timing will make the combustion temperatures higher?
